02 Tacoma heater valve stuck
Discussion in '1st Gen. Tacomas (1995-2004)' started by CraigMac1976, Sep 13, 2021.
  1. Sep 13, 2021 at 11:51 AM
    CraigMac1976
    CraigMac1976 [OP] New Member
    02 Tac reg cab man. 4cyl
    It’s stuck but knob on inside moves normal
  2. Sep 13, 2021 at 12:35 PM
    tmross
    tmross Well-Known Member
    2002 Tacoma 2.4L 2wd Reg Cab
    Are you able to open and close the valve manually by pushing the lever back and forth?
    I had issue with mine and it turned out to be the cable that hooks up from the servo motor to the valve lever was seized. Replaced the cable and works perfect.
  3. Sep 14, 2021 at 5:52 AM
    CraigMac1976
    I was able to unhook cable and move lever.
    Open valve but still not getting heat.. any suggestions. I am going to replace cable.
  4. Sep 14, 2021 at 6:09 AM
    tmross
    Air blend mechanism has 2 components - valve has to be open, and that metal apparatus under the dash that attaches to the servo motor has to be engaged in the open position. Hard to explain but I discovered just opening the valve manually wasn't enough. Reach under the dash and push/pull the lever/linking arm that the cable is attached to. You might have to remove the servo motor. Not exactly sure what the anatomy is down there but perhaps that apparatus is simultaneously opening a vent under the dash while the cable is opening the valve in the engine bay.
    In any event if you take the cable out and you feel resistance in it thats probably your problem. Mine wasn't totally stuck, it was just tough, and lubing didnt help. I ordered a new one and the new one had 0 resistance at all, its supposed to glide effortlessly. Also make sure the servo motor isnt dead.
  5. Sep 14, 2021 at 6:57 AM
    CraigMac1976
    I will get under there and check that out, thank you sir!
