02' Tacoma, rear end seems to drag on turns
Discussion in '1st Gen. Tacomas (1995-2004)' started by JohnnieFive, Oct 8, 2011.
  1. Oct 8, 2011 at 6:26 PM
    JohnnieFive
    JohnnieFive [OP] Well-Known Member
    Johnny
    Anaheim, Ca
    07' Tacoma PreRunner TRD Sport
    I have an 02' PreRunner DC 2wd, when im coming around a sharp turn my rear end seems to drag a bit, this is my 1st Tacoma so i don't know much about them, anyone ever had the same problem
  2. Oct 8, 2011 at 6:28 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 Auto Trans With Lots of Mods King Extended Travel COs Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Alcan Custom 8-Leaf Rear Spring Packs Fox 2.0 Resi Rear Shocks FrankenFab Rear Shock Relocate All-Pro U-bolt Flip w/Timbren bumps Toytec 1" Extended Shackle 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Gunmetal 16x8 SCS Ray10s 285/75r16 Cooper STT Pros Limited Edition Relentless Front Bumper Smittybilt X2O 10K Winch 3" LED Pods w/Amber covers in the Bumper 22" Single Row LED Bar on the Bumper Mini D2S Projectors XB35 Ballasts + 4500K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Whynter 65 qt. Fridge/Freezer CVT Mt Bachelor RTT Badland Custom Bed Rack GM 140 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Magnaflow 18" Muffler 13WL Brake Calipers Braided Steel Brake Lines AFE Pro Dry S air filter ScanGauge II OBDII Scanner Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    it'll do that if the e-locker is engaged. :rolleyes:
  3. Oct 8, 2011 at 6:32 PM
    JohnnieFive
    Johnny
    Anaheim, Ca
    I've checked and its off
  4. Oct 8, 2011 at 6:38 PM
    JohnnieFive
    Johnny
    Anaheim, Ca
    that could be possible, i personally havent checked it..gonna look into that
  5. Oct 8, 2011 at 6:40 PM
    Digiratus
    Roaming the PNW
    The RedHead
    How do you know? Because the dash light is off? Put the axle on jack stands and spin one tire. If the e-locker is disengaged, the opposite wheel will spin in the opposite direction.
  6. Oct 8, 2011 at 7:05 PM
    Yoytoda
    Yoytoda The Little Truck That Could
    Roland
    Big Bear,CA / Upstate NY(Saratoga)
    2010 Tacoma Regular Cab 4x4
    completely stock
    what is rear end dragging?
    maybe new leaf springs?
  7. Oct 8, 2011 at 7:11 PM
    oneBIGroom
    oneBIGroom SSS
    SSS
    SSS
    SSS
    SSS
    X2. I've read about problems with the locker being stuck.
