02 Tacoma Rusted Frame ~ Letter to Toyota...
Discussion in '1st Gen. Tacomas (1995-2004)' started by Tic Taco, Feb 11, 2010.
  1. Feb 11, 2010 at 10:20 AM
    Tic Taco
    Tic Taco [OP] Well-Known Member
    This is the letter I just sent to Toyota, your thoughts?
    I, like most Tacoma owners bought my truck because I believed Toyota
    was a company that stood behind their products & you could count on them
    to do the right thing. I am greatly disappointed in how Toyota is handling
    my Toyota Tacoma rusted out frame replacement warranty operation.
    I am unemployed at this time & really don’t appreciate the added burden of
    the cost Toyota is putting on me & I believe it is quite unfair.
    This is my complaint: I added a class 3, two inch trailer hitch to my 2002 Tacoma.
    It uses 4 bolts, two 10mm factory & two supplied with the new hitch. Well BECAUSE
    the frame is so rusted, one of the 10mm factory bolts broke off when I tried to remove
    it to mount my trailer hitch (I was using a hand ratchet, NOT an air tool). So now I only
    had 3 bolt points for a 4 bolt hitch, and I had to have the hitch welded onto the frame.
    Well now BECAUSE the rusted out frame has to be replaced, my trailer hitch I
    normally wouldn’t have done anything with, cannot be removed & reinstalled
    on the replacement Toyota frame. The trailer hitch needs to be replaced BECAUSE the
    frame needs to be replaced – and the hitch was welded BECAUSE of the rusted frame!
    I don’t believe my Tacoma should be better than it was before the frame replacement,
    But it shouldn’t be LESS than what I had before the frame replacement either! I have
    petitioned Toyota, (both dealership & corporate) They told me “Sorry, we won’t cover
    your trailer hitch” I believe Toyota caused me this loss and they should be the ones
    to cover the cost of it. Toyota is going to pay $10,000 to $12,000 to do this rusted out
    frame replacement operation. In comparison, why not cover the cost of the trailer hitch
    (approx. $200) on my $8,000 to $9,000 Tacoma. (And/ or why doesn’t Toyota buy this
    truck back like they did with others?)
    I don’t believe Toyota is doing all they could or should in my case - the lack of
    covering a $200 part is costing them a LOT of ill will. Toyota shouldn’t simply say
    “Sorry”. Toyota needs to do the right thing… and strive for customer satisfaction
    in accommodating my loss as a result of their frame replacement repair.
  2. Feb 11, 2010 at 10:29 AM
    Mark C.
    Mark C. If you want it bad, you usually get it bad!
    Mark
    Connecticut
    2010 MGM SR5 4WD AC
    LED Dome, Reed Switched LEDs in Glove Box and Center Console, Bumper Fogs, Tailgate anti-theft, LEDs over Cig lighter, Back-up camera anytime, Outside Temp add-on, Hidden GPS power, Sockmonkey 3rd Brakelight decal, 4X4 switch illumination, reed switch controlled engine compartment Flood LEDs, Elite Hitch Cover, Plasti-dipped cupholders and door switch control panels, Elite Hitch Cover.
    Good for you! And well said... I was lucky that with my 2000 and the after-market hitch, they listed it as having a "towing package" for pricing of the buy back.
    Sorry they won't fix you up with a new hitch.......but maybe your letter will make a difference! Best of luck and keep us posted as to how you make out!
  3. Feb 11, 2010 at 10:35 AM
    slickyd
    slickyd Well-Known Member
    David
    Alex City, AL
    03 PreRunner SR5
    I think I'm with Toyota. Sorry. Something about this makes me feel like they aren't doing anything wrong.
  4. Feb 11, 2010 at 10:42 AM
    Tic Taco
    Could you please expand / explain what this “something” is
    that would have you side with Toyota on this situation?
  5. Feb 11, 2010 at 11:12 AM
    Worm
    Worm Well-Known Member
    Scott
    Southern Maryland
    I agree, Toyota is addressing the frame warranty issue and replacing the frame, anything other than factory installed is really not there concern.
  6. Feb 11, 2010 at 11:14 AM
    Worm
    Scott
    Southern Maryland
    And I know that sounds cold but thats just the way it works.
  7. Feb 11, 2010 at 11:31 AM
    Tic Taco
    Agreed, but is it the way is should work?
  8. Feb 11, 2010 at 11:37 AM
    Worm
    Scott
    Southern Maryland
    Depends on your point of view, from the consumer ofcourse not just doesn't seem fair. But from the company's point of view its the only way to be fair to everyone, do only what is nessary to correct the company's fault. It has to be that cut and dry unfortunatly because if they get into peoples modifications and rebursing them for loss of parts, then it would consume a rediculous amount of time. And in the end would leave both parties unsatisfied.
  9. Feb 11, 2010 at 11:50 AM
    n315on
    n315on Well-Known Member
    MA
    02 4x4 SR5
    3'' toytec lift springs wrapped around 5100's. Deck plate mod. TRD seat belt pads. JL audio amps /subs and Alpine speakers. Diff breather mod. Working on a custom rear bumper
    Like he said ^^ it could go either way depending how you look at it. I think it's good that you are standing up for what you believe in though. Plus you already wrote the letter why not send it. Good luck.
  10. Feb 11, 2010 at 11:52 AM
    Afwrestler1986
    Afwrestler1986 Well-Known Member
    Johnstown, NY
    01 trd 4X4 ex cab manual
    Gray wire, Some lights in the bed area, and some character marks throughout.
    Well written. It sucks yes. However, one could say that the frame rusting ruined the rigidity of the frame thus causing excessive tire wear for the last 6 years and I would like you to replace my tires for that time period.
    In your case, you lost a hitch valued at approx. 200 bucks. Well, say they have 1000 Tacomas need the frame replacement. The replacement is valued at say 10,000 bucks.
    For just the frame job it comes out to $10,000,000
    Now add a $200 for each(Assuming everyone has a part that required more than usual attention due to frame) and that comes out to $200,000.
    So a total of $10,200,000.
    It sucks for you yes, but if they bend the rules for one, they would have to accomodate everyone to the point of Toyota no longer existing, which in turn would cease any and all frame replacements permanently.
  11. Feb 11, 2010 at 12:07 PM
    rab89
    rab89 Well-Known Member
    Ross
    Kelowna b.c canada
    2012 DCLB
    Grillcraft mx black upper and lower BHLM with Gloss black 265 70 17 bfg a/t center console light mini mag mounted in center console debadged bed lights 35W 5000k HID's
    Come on man, when you installed the hitch did you properly prep the surface? because if you mounted it to a rusty frame, your fault.
    If the bolts were so rusty that they broke, I'd imagine it wasn't prepped properly, if you hadn't tried to remove the hitch because of the frame replacement, you would have attached a trailer, and it would potentially fall off.
    Also, you could have drilled out the broken bolt, tapped the hole (if needed) and bolted it back up.
    So, if you did prep properly, as in scrape the mounting points down to bare metal, paint and then attach the hitch, then you are in the right. but it doesn't sound like that is the case
  12. Feb 11, 2010 at 3:06 PM
    slickyd
    David
    Alex City, AL
    03 PreRunner SR5
    I agree with everyone below me for my reasons for being on TOYOTA's side.
  13. Feb 11, 2010 at 3:14 PM
    WNYTACOMA
    WNYTACOMA Well-Known Member
    Clarence, New York
    09 Metalic Grey TRD OFF ROAD
    Toyota Nerf steps Bugflector 2 Tool box Weathertech floor liners Wet Okole F/R - Bk/Char
    Agreed.
    It is ridiculous (or rEdiculous, for the challenged) to expect Toyota to replace not only the frame but the aftermarket crap attached to it.
    My advice would be to get a grip and gracefully eat the $200 bucks while Toyota voluntarily eats the $10,000-$12,000.
    Who the hell else stands behind their stuff like that?
  14. Feb 11, 2010 at 3:41 PM
    Tic Taco
    Thank you guys, I asked for feedback & I got it! :cheers:
    I still can’t help but wonder how some of you
    would truly feel about this if it were your Tacoma
    going through this little ordeal. I do respect your
    opinions nonetheless. Thanks again :taco:
  15. Feb 11, 2010 at 4:51 PM
    gusotto
    gusotto gusotto
    Gary
    Iowa
    2001 Tacoma 4X4 SR5 Extended Cab
    I had the frame replaced on my 2001 AC.
    I have an after market hitch on the truck.
    It was removed for the replacement frame and later reattached when the frame job was done.
    If you were breaking bolts and then welding to a rusty frame, that is just plain dangerous.
    If the frame was so rusty, what makes you think it would tow anything safely?
    Anytime an item is welded to the frame, I consider it attached forever!
    A new hitch isn't too expensive but good luck with the job hunt.
    Toyota has given you a brand new frame with new springs, brake lines, lower control arms, emergency brake cable, hardware, fresh antifreeze, brake fluid, A/C recharge and free labor.
    Toyota has extended the life of your truck for many years and you're whining about a frame hitch?
    I give Toyota an atta boy. They have gone far beyond anything expected.
    I know I'm happy with my frame replacement!
  16. Feb 11, 2010 at 7:01 PM
    747
    747 function > form
    1st Gen.
    I'm with Tic Taco...not the fanboys!:D
    Give'em hell, Tic. Don't take their sh!t! It's clear that you relied on their representation of Toyota Tough in the purchase of your vehicle. Acting on that reliance, you installed a trailer hitch. Because of Toyota's failure to deliver on "Toughness", you're out two bills.
    As for the fanboys...karma's a b!tch dudes.:cool:
  17. Feb 11, 2010 at 7:37 PM
    Worm
    Scott
    Southern Maryland
    Thats all fine and dandy lol but the fact remains this battle over the hitch is a lost cause.
  18. Feb 11, 2010 at 8:10 PM
    747
    747 function > form
    1st Gen.
    Oh yeah...yer SOL Tic...but don't let that stop you.
  19. Feb 12, 2010 at 4:28 AM
    slickyd
    David
    Alex City, AL
    03 PreRunner SR5
    how about this... If I had to get my frame replaced and I had rock sliders welded to the frame I wouldn't except them to buy me new sliders. I would either take them off or suck it up and deal with my loss.
  20. Feb 12, 2010 at 4:41 AM
    swise
    swise TRIFECTA!!!
    ohio
    08 4x4 dbl cab, TRD offroad
    Sorry about your situatuion, But I too have to agree with Toyota on this one. You decided to weld the hitch on, against the correct way, even though it was your only option at the time. They are replacing the bad part(frame) but I doubt they will cover any non OEM modification done to it, which would be a welded on hitch.
