02 Tacoma Signal light problem.
Discussion in '1st Gen. Tacomas (1995-2004)' started by dentedmetal23, Aug 11, 2015.
  1. Aug 11, 2015 at 8:54 AM
    dentedmetal23
    dentedmetal23 [OP] New Member
    Colorado
    2006 Tacoma TRD
    I have an 02 Tacoma double cab and I have problem with my signal lamp on my drivers tail lamp. the bulb is fine and blinks the it is very intermittent with the flashing speed. Any help would be appreciated. Thank you.
  2. Aug 28, 2015 at 3:13 AM
    Cruzintaco
    Cruzintaco Well-Known Member
    Sanjose
    2001 PreRunner TRD
    K&N drop in filter EGR Silencer Delete More MODS soon to come!
    Check you ground cables.. that could cause an issue. And turn on your hazards.. see if theres a difference in the 2 tail light assemblies. I believe if the drivers side is dimmer it could be a faulty ground or 12v wire
    (experience: similar problem happened to me, and had a faulty ground)
  3. Aug 28, 2015 at 4:01 AM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    If you have a trailer light harness, check the plug for corrosion. Very common for a corroded plug to screw up the truck's lighting system.
    Joe_from_iowa likes this.
  4. Aug 28, 2015 at 6:15 AM
    keakar
    keakar Well-Known Member
    karl
    louisiana
    mainly its in that little converter box between the plug and tail light wires, the little circuit board inside them shorts out
  5. Aug 28, 2015 at 8:10 AM
    koditten
    Kirk
    Central Michigan
    So true, Karl, but usually you only lose the trailer lights when that box goes. Corrosion on the plug will back feed into the light system and cause issues with lights on the truck.
