'02 Tacoma Sitting For Two Years--How to Restore?
Discussion in '1st Gen. Tacomas (1995-2004)' started by LongEnoughCrazy, Aug 24, 2023.
  1. Aug 25, 2023 at 7:55 PM
    CVCV
    CVCV 3rd Toyota Truck
    Tacoma 2022 3.5L DCSB TRD OR 4x4
    Pulling the EFI fuse is a smart move.
    My brother has a ‘96 4-cylinder and I think it has the old style ignition. Don’t know what year it changed but I like having the new equivalent of pulling the coil wire.
  2. Oct 4, 2023 at 4:01 PM
    LongEnoughCrazy
    LongEnoughCrazy [OP] Active Member
    Hello everyone.
    Thank you for your help. I have followed your advice. Here is what I did, in order.
    1) change the battery to a new one
    2) check that the instrument panel lights up (yes)
    3) inflate the tires to the appropriate pressure
    4) change the oil and oil filter and oil pan washer (OEM Toyota filter purchased on Bezo's website, Mobil brand 5w-30 oil because that's what was lying around)
    5) fill the gas tank with fresh gasoline (regular 87). The vehicle had less than a quarter tank of old gasoline in it prior to adding.
    6) Pull the EFI fuse
    7) Turn the engine over five times, 12.5 seconds each time, with a 30-second rest interval in between times.
    After performing these steps, the truck seems to be running fine. I have not yet taken it on the road but expect there will be no problem.
    Thank you for your help! Of course, if I did anything wrong, please let me know. I hope this thread can be useful for other novices who let their vehicle sit too long.
    rocknbil and RedWings44 like this.
  3. Oct 4, 2023 at 4:08 PM
    RedWings44
    RedWings44 Well-Known Member
    Michigan
    2017 Black TRD Off Road 4x4, 2019 MGM 4Runner SR5
    Thanks for the update!
