'02 Tacoma stumbles on acceleration.
Discussion in '1st Gen. Tacomas (1995-2004)' started by 42ndego, Feb 13, 2014.
  1. Feb 13, 2014 at 7:46 AM
    42ndego
    42ndego [OP] Member
    Sky
    Phoenix
    '02 PreRunner
    I've recently replaced the engine on my '02 Taco, 2.7L, 4cyl, auto, standard cab and I'm running into some trouble. Every time I start it up it idles somewhat rough and when I take off down the road it runs fine for a minute or two, then it starts to stumble.
    So far I've:
    - Replaced oil pressure switch
    - Replaced both O2 sensors
    - Cleaned out MAS
    - Replaced all plugs
    These were just things I did after the swap. Any help would be greatly appreciated!
  2. Feb 13, 2014 at 7:48 AM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    With the engine idling tap the MAF lightly with the handle of a screwdriver; if the idle fluctuates the MAF is bad. Make sure the EGR is working correctly and you have no vacuum leaks. In fact I'd start replacing the vacuum lines. I think the Coolant Temp Switch can be a problem, too.
  3. Feb 13, 2014 at 8:46 AM
    42ndego
    42ndego [OP] Member
    Sky
    Phoenix
    '02 PreRunner
    I've already replaced the coolant temp switch, I forgot to mention that.
    The EGR was my next step. I'll try out the tapping trick with the MAS tonight and taking a look at the EGR as well, maybe it's stuck. Thank you for the tip!
  4. Feb 13, 2014 at 9:55 AM
    se7enine
    se7enine MCMLXXIX
    Reno, NV
    You could also just unplug the maf then start it and see if it idles better or worse. It will run in limp mode but you should be able to tell the difference. Also did you replace the plug wires with the spark plugs? If the plug wire isn't fully seated on the spark plug then you will stumble when you start driving too, check to see if they are nice and tight. I had a stumble and replaced my plugs and wires as well as the cap and rotor. Not sure if you have that or just coil packs.
  5. Feb 13, 2014 at 10:03 AM
    42ndego
    42ndego [OP] Member
    Sky
    Phoenix
    '02 PreRunner
    I will double check the wires, I didn't replace any of them so who knows?
  6. Feb 13, 2014 at 10:20 AM
    tan4x4
    tan4x4 Well-Known Member
    Rick
    Folsom, CA
    99 Tacoma EC 4x4 2.7L Auto
    Bilsteins, OME 881's, 3-leaf AAL, Detroit TruTrac, Tundra brake swap, Michelin LTX AT2, Tranny skidplate, TC skidplate, CBI rear bumper, TG sliders, UltraGauge, PowerTank, Reverse Camera
    What is the source of your replacement motor?
    Was the donor vehicle from the same year? Same tranny?
  7. Feb 13, 2014 at 12:46 PM
    Steves104x4
    Buffalo NY
    2010 RC 2.7 4x4
    ^^ Ya, I wasn't gonna say nothin'. That is a big ? and why.
  8. Feb 13, 2014 at 12:48 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Sounds like a vacuum leak to me based upon the history of the vehicle.
  9. Feb 14, 2014 at 10:52 AM
    42ndego
    42ndego [OP] Member
    Sky
    Phoenix
    '02 PreRunner
    The new motor was a rebuilt from a shop. Same size as the original. As far as the stumbling goes, turns out it was a loose ground. Once I tightened it down it stopped immediately :D
  10. Feb 15, 2014 at 7:29 AM
    tan4x4
    Rick
    Folsom, CA
    Glad it was an easy fix. Thanx for sharing with us.:cool:
