02 Trd rear dif question
Discussion in '1st Gen. Tacomas (1995-2004)' started by Merc1100sc, May 25, 2013.
  1. May 25, 2013 at 5:17 PM
    Merc1100sc
    Merc1100sc [OP] Member
    Hello everyone. I have an 02 Tacoma Trd x cab v6. I was changing my rear dif fluid today and noticed what looks like a small vent line of some sort coming out of the rear locker actuator section. Can anyone tell me what this is and what it's for?
    Thanks
  2. May 26, 2013 at 7:35 AM
    bowyer2002
    bowyer2002 always tinkering
    NE Missouri
    01 Taco SR5 D-cab 4WD
    OME 882s, OME shocks all around and OME Dakar spring packs, ARB, Warn 8000, ARE shell, Custom rear bumper w/ reciever, 5-235/80R17 Cooper Discoverer ST MAXX on FJ wheels, grey wire mod, Hi-Lift, Hellas, Red-Line hood lifters, Scion radio, sliders, Safari snorkel & LED Ditch lights on CBI mounts.
    it's your diff breather which allows the air & fluid in the diff to expand/contract and not create undue pressure/vacuum within the diff.
    if you plan on offroading & doing water crossings it is advised to raise this breather line above the possible submerged water line you may encounter.
    search differential breather extension for more info
  3. May 26, 2013 at 1:48 PM
    Dirty Pool
    Dirty Pool FLIES ON THE FRIES, KETCHUPS WATERED DOWN
    59.4 Miles, 56.67° NE Of Moab
    99 XCAB V6 MT TRD
    Dirty Pool rear bumper/air tank with integrated spare CV shaft storage, DP customized TJM front bumper, 8000 lb Ramsey/Technora rope, E-locked, Extended breathers with front diff catch can, PCV catch can, SAWs with DP heim joint seals, DP custom 6 leaf rear springs/Billies, DP custom skids, 2lo, Gray wire, Cap, Bed Rug, Black steelies, 01 Center console, Map lights, Disraeli gears
    That is the locker actuator breather. Differential housing breather and locker breather are two different things.
    The locker breather goes up to the frame with the locker wiring harness. On the end is a funky little rubber tip that can get hard or fall off.
    This breather is often neglected, many folks don't know it's there.
