02 vacuum 4x4 issues
Discussion in '1st Gen. Tacomas (1995-2004)' started by thatblack_taco, Nov 17, 2022.
  1. Nov 17, 2022 at 8:58 AM
    thatblack_taco
    thatblack_taco [OP] New Member
    Ian
    02 Tacoma 2.7l 5spd
    Yukon lsd disc brake conversion electric e brake and few other little things.
    I have an 02 taco with a vacuum actuator for the 4x4 I found my 4x4 wasn’t working after buying the truck I found the line not connected to anything and I was curious if anyone knew what type of vacuum I have to hook the line to suction type or push type?
  2. Nov 17, 2022 at 9:01 AM
    02hilux
    Planet: EARTH
    01+ are electronic, not vacuum
    Kwikvette likes this.
  3. Nov 17, 2022 at 9:02 AM
    thatblack_taco
    Ian
    02 Tacoma 2.7l 5spd
    Then I have a bigger problem there’s only a vacuum line going to my front diff there’s no wires of any kind going to it.
  4. Nov 17, 2022 at 9:04 AM
    02hilux
    Planet: EARTH
    Your actuator will be located on the passenger side cv. The cv axle go into it.
    The line/hose you're referring to is the vent
    wilcam47 and Kwikvette like this.
  5. Dec 9, 2022 at 7:31 AM
    Rusty taco 101
    Rusty taco 101 New Member
    02 trd
    Anyone know where that vent line goes too? And how important is it what would happen if it was clogged
  6. Dec 9, 2022 at 7:36 AM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    if its clogged it could make the seals leak...it should go up in the engine bay with a vent cap
  7. Dec 9, 2022 at 7:42 AM
    Rusty taco 101
    02 trd
    Awesome thank you I'll have to trace the line and check it out mine was disconnected and caused my actuator to fail
