02 Wheel bearings
Discussion in '1st Gen. Tacomas (1995-2004)' started by Octain, Jan 10, 2015.
  1. Jan 10, 2015 at 11:07 AM
    Octain
    Octain [OP] Member
    Ga
    02 quad cab Pre-Runner
    Hello, I have concluded that my 02 2wd Pre-Runner needs new front wheel bearings. It has 170k miles so I think it's done pretty well.
    I can handle most tasks with a little research. Problem is, I cant find much info on the first gen Tacoma wheel bearing replacement.
    Can anyone point me in the right direction?
  2. Jan 10, 2015 at 11:16 AM
    tomtom
    tomtom Well-Known Member
    The Desert SW
    2012 FJ
    If they are like the 4WD bearings, they have to be pressed out and in and can be quite the PITA. Most people take the spindles to a competent garage or dealership and have them do it for them.
  3. Jan 12, 2015 at 2:04 PM
    Octain
    Octain [OP] Member
    Ga
    Looks like that's what I'm gonna do. Spoke to a dude today at a local garage, said he'd do it for 150-160 bux. I'm on that like white on rice.
    Thanks!!
  4. Jan 12, 2015 at 9:46 PM
    Zer0
    Zer0 Well-Known Member
    SGV, California
    99 PreRunner
    good idea I will do the same. you guys are clever
  5. Jan 13, 2015 at 11:12 AM
    keakar
    keakar Well-Known Member
    karl
    louisiana
    save your money guys, the 2wd trucks have normal standard 2 piece bearings that are easy to replace for under $30 for both sides.
    the rotors on these trucks cost $30 each and are bolted on from the back side of the hub so since the hubs have to come off to replace/regrease the bearings, this is the time to replace the brake rotors if there is any signs or wear on them.
    I suggest you cover all bases and do brakes and bearings together since you have to take them off anyways.
    nothing is pressed on unless you have a 4wd truck
  6. Jan 13, 2015 at 12:27 PM
    Dirty Pool
    Dirty Pool FLIES ON THE FRIES, KETCHUPS WATERED DOWN
    59.4 Miles, 56.67° NE Of Moab
    99 XCAB V6 MT TRD
    Dirty Pool rear bumper/air tank with integrated spare CV shaft storage, DP customized TJM front bumper, 8000 lb Ramsey/Technora rope, E-locked, Extended breathers with front diff catch can, PCV catch can, SAWs with DP heim joint seals, DP custom 6 leaf rear springs/Billies, DP custom skids, 2lo, Gray wire, Cap, Bed Rug, Black steelies, 01 Center console, Map lights, Disraeli gears
    Completely false, prerunners are the same as 4wd as far as the bearings.
  7. Jan 13, 2015 at 12:41 PM
    keakar
    karl
    louisiana
    thanks, I didn't realize that
    geez that's stupid, do they have CV joints too?
    if prerunner is a 4wd only using 2wd they should just call it that
    thank god I wasn't dumb enough to buy a prerunner with all the extra expense for everything
  8. Jan 13, 2015 at 12:49 PM
    tomtom
    The Desert SW
    2012 FJ
    No CV axles, no front diff, no front drive shaft, no transfer case.
    Not sure what you mean by "4WD only using 2WD".
  9. Jan 13, 2015 at 12:54 PM
    keakar
    karl
    louisiana
    because it seams everything on a prerunner uses 4wd parts, the only thing missing is the axles and differential
    why does a 2wd prerunner need $80 press in bearings requiring shop service while a regular 2wd uses $6 bearings that are not pressed in that anyone can do in their driveway
  10. Jan 13, 2015 at 1:15 PM
    tomtom
    The Desert SW
    2012 FJ
    Ah. Gotchya now.
    I'm guessing Toyota identified a large buyer segment that wanted the more rugged look but not the added expense. Easy solution was to modify the 4wd models by removing the front drive mechanisms.
    The prerunner even came with the rear locker on the TRD models.
  11. Jan 14, 2015 at 8:02 AM
    Octain
    Octain [OP] Member
    Ga
    They do. It's called a 2wd Pre-Runner.
    Because they LOOK better than a little mini pickup.:eek:
