03 2.7 Engine Sputter and Dies when cold
Discussion in '1st Gen. Tacomas (1995-2004)' started by wolfman73, Mar 13, 2017.
  1. Mar 13, 2017 at 9:01 AM
    wolfman73
    wolfman73 [OP] Member
    2014 TRD
    Hi Group!
    I hope you are having a good day! I wanted to see if anyone has run into this problem before and what they found to be the resolve. I have an 03 tacoma 2.7 4x4 that I recently purchased. The issue that I am having is that when the truck is cold it will sputter while at idle and when driving it will sputter and die. Once it warms up it seems to be fine. It has a Volant Cold Air Intake as well as an aftermarket header. The odd thing is is that it doesnt throw the check engine light to indicate what the issue is. Any thoughts?
    Thanks
  2. Mar 13, 2017 at 9:05 AM
    tan4x4
    tan4x4 Well-Known Member
    Rick
    Folsom, CA
    99 Tacoma EC 4x4 2.7L Auto
    Bilsteins, OME 881's, 3-leaf AAL, Detroit TruTrac, Tundra brake swap, Michelin LTX AT2, Tranny skidplate, TC skidplate, CBI rear bumper, TG sliders, UltraGauge, PowerTank, Reverse Camera
    Could be the MAF sensor (part of a stock intake), if your truck still has it. The MAF also includes the air temp sensor (at least it does on my '99 3RZ)
    nDub and knayrb like this.
  3. Mar 13, 2017 at 9:52 AM
    Glamisman
    Glamisman Well-Known Member
    the CEL(check engine light) will only be tripped when a certainset or parameters are exceeded... there is more than likely a "pending" code that could lead you to a starting point.
  4. Mar 13, 2017 at 11:17 AM
    Taco_4x4_Guy_
    Taco_4x4_Guy_ Member
    USA
    2017 Toyota Tacoma DC TRD Off Road Premium
    3" Toytech Lift, Toyota Billstein Shocks, TRD Pro Grill, 18" Fuel Rims with 285 65 R18 Cooper Discovery SST Tires.
    I used to have a 94 T100 with the dreadful 3.0L V6 and had the same symptoms plus white smoke bellowing out of the tailpipe. My issue was a blown head gasket.
  5. Mar 13, 2017 at 12:33 PM
    wolfman73
    2014 TRD
    Hi
    Glamisman,
    Is there a way to check for "pending" codes?
  6. Mar 13, 2017 at 5:46 PM
    tan4x4
    Rick
    Folsom, CA
    The Ultragauge will detect 'pending' codes. Not sure about scangauge or other code readers.
  7. Mar 14, 2017 at 6:34 AM
    wolfman73
    2014 TRD
    Thanks guys! I am going to pick up a scanner and plug it in while I drive to try and catch the pending code. I will post my findings.
