03 2.7 hard to go into 1st after new clutch
Discussion in '1st Gen. Tacomas (1995-2004)' started by Twesty32, Jun 28, 2013.
  1. Jun 28, 2013 at 8:03 PM
    Twesty32
    Twesty32 [OP] Member
    I just installed a marlin 1600 heavy duty clutch in my 2003 Tacoma. I also had to replace the clutch fork and pivot, the truck would barely go into gear before, you would have to shut it off sometimes to get it to go into 1st. before all that it shifted fine and went into first just fine. also I resurfaced the flywheel. now the truck is hard to get into first, it does not grind or anything it just doesn't want to go in. I lubed the throw out bearing and clutch fork, also I have bled the slave cylinder and changed the clutch fluid, the trans fluid is new also. I don't think it is a slave or master issue because it doesn't grind. I was wondering what you guys thought it might be?
    Thanks a lot,
    Tim
  2. Jun 28, 2013 at 8:40 PM
    01Tac0ma
    01Tac0ma Bash Fabriction & Off-Road
    Chad
    West Columbia, SC
    SAS 01 TRD 4x4
    Look at build!
    Mine did this after I first put the same clutch in, the throwout bearing had come off the clips and been destroyed.. might want to take the rubber grommet off driver side and take a peek inside to be sure its still on the clips correctly
  3. Jun 30, 2013 at 6:54 PM
    Twesty32
    It does grind when i push the cluch in, it just seems like it doesnt want to go into first. Im going to pull the cover off and take a look this week. It has got me stumped.
  4. Aug 25, 2013 at 10:17 PM
    Twesty32
    its not the throw out bearing, it all looks good. idk what is causing it
  5. Aug 25, 2013 at 10:21 PM
    tan4x4
    tan4x4 Well-Known Member
    Rick
    Folsom, CA
    99 Tacoma EC 4x4 2.7L Auto
    Bilsteins, OME 881's, 3-leaf AAL, Detroit TruTrac, 31" tires, Michelin LTX AT2, Tranny skidplate, TC skidplate, CBI rear bumper, TG sliders, UltraGauge, PowerTank, Reverse Camera, CB
    Does the slave cylinder move that fork enough?
    Try bleeding it again.
