03 4x4 3.4 differential fluid change and trans fluid change
Discussion in '1st Gen. Tacomas (1995-2004)' started by wolfman73, Jun 8, 2017.
  1. Jun 8, 2017 at 7:40 AM
    wolfman73
    wolfman73 [OP] Member
    2014 TRD
    Good Morning Group.
    I am wanting to change the front/rear diff fluid as well as my trany fluid in my 03 4x4 tacoma and was wondering what type/weight fluid to use in the differentials? Also, I am going to change the trans fluid as well and wanted to know if there is a specific brand of trans fluid that is suggested and is there a filter that I can change once I drop the drain pan?
    Thanks!!
  2. Jun 8, 2017 at 10:20 AM
    Jckdnls
    Jckdnls Roads less explored
    Spicer, mn
    93 3.0 v6 sr5 5spd 08 ac or 6sp
    Dakar torsion bars
    Auto? Manual? Diff I use Castro. Synthetic 80w90 along with my tranny. N tcase but I have a manual change all yearly.
  3. Jun 8, 2017 at 10:23 AM
    wolfman73
    2014 TRD
    Sorry..its an auto trans.
  4. Jun 8, 2017 at 11:44 AM
    r45d
    r45d Well-Known Member
    Georgia
    01 DC 4WD
    http://www.4x4wire.com/toyota/maintenance/tacoma_4runner_30k/maintenancep4.htm decent write up to include diffs and tranny.
    https://www.tacomaworld.com/threads/fun-transmission-fluid-and-filter-change.97562/ some good info and links
    I just go to wal-mart buy the valvoline maxlife synthetic dex/merc gallon, drain the pan and replace what comes out. I do this about every third or fourth oil change. Nothings blown up or over heated yet...2001 DC V6 auto.
    The diffs are straight forward just make sure you have the sockets and hex drives and a fluid pump.
  5. Jun 8, 2017 at 11:46 AM
    eon_blue
    Azusa, CA
    Front and rear diffs (and transfer case) take 75w90 gear oil....I use Valvoline brand myself but Redline is a highly recommended brand on here. The auto trans doesn't take gear oil like the manual trans does, it takes ATF (automatic transmission fluid). Not sure on which one specifically but I hear that it's best to stick with the Toyota brand
  6. Jun 8, 2017 at 11:49 AM
    eon_blue
    Azusa, CA
    ^^^ this, the diffs and t-case are really easy to do yourself, no need to pay crazy labor fees on stuff like that. But be sure that you loosen the fill plug on them BEFORE removing the drain plug. You don't want to drain them only to find out that you can't get the fill plug loose to put more in...
  7. Jun 13, 2017 at 9:52 PM
    phobostx
    phobostx Well-Known Member
    Rich
    Austin, TX
    00' 4Runner SR5 4WD
    Amsoil is my go to for differential fluids.
