03 4x4 how to make it ride smoother
Discussion in 'Suspension' started by rangerthug, Mar 10, 2011.
  1. Mar 10, 2011 at 6:49 AM
    rangerthug
    rangerthug [OP] New Member
    valrico,fl
    03 4x4 tacoma
    i just bought a 2003 taco 4x4 double cab it has a small lift not sure of the size. the tire are 265-16 in it rides very rough its stiff as a board .how can i make it ride better?my buddy has a 2001 prerunner i was looking at the leaf spring on that prerunner the bottom spring is arch down,mine or straight. can i change the leaf springs out with the prerunner springs an get a better ride?
  2. Mar 10, 2011 at 9:48 AM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 Auto Trans With Lots of Mods King Extended Travel COs Camburg Uniball UCAs Alcan Custom 8-Leaf Rear Spring Packs Fox 2.0 Resi Rear Shocks FrankenFab Rear Shock Relocate All-Pro U-bolt Flip w/Timbren bumps Toytec 1" Extended Shackle 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Gunmetal 16x8 SCS Ray10s 285/75r16 Cooper STT Pros Limited Edition Relentless Front Bumper Smittybilt X2O 10K Winch 3" LED Pods w/Amber covers in the Bumper 22" Single Row LED Bar on the Bumper Mini D2S Projectors XB35 Ballasts + 4500K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Whynter 65 qt. Fridge/Freezer CVT Mt Bachelor RTT Badland Custom Bed Rack GM 140 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Magnaflow 18" Muffler 13WL Brake Calipers Braided Steel Brake Lines AFE Pro Dry S air filter ScanGauge II OBDII Scanner Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    Welcome to TW.
    Post up some pics of the front coilover assemblies and the rear springs so we can see what you have. Are the tires 265/70/16 or 265/75/16?
