03 5 speed manual Tacoma won't start in neutral
Discussion in '1st Gen. Tacomas (1995-2004)' started by Yoda2k15, Dec 31, 2020.
  1. Dec 31, 2020 at 10:08 AM
    Yoda2k15
    Yoda2k15 [OP] New Member
    2015 TRD off road
    When I go to start the truck I will have the clutch all the way in and be in neutral and it will start for a second then immediately turn off. When I put it in 1st gear the truck starts right up. Any ideas on what could be happening?
  2. Dec 31, 2020 at 12:59 PM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    Some back ground Did this just start ?? New to you truck ??
    Might very well be some sort of anti theft idea the truck only cranks and starts in first gear.
    Unless moving the clutch pedal is enough to close the clutch safety switch.
    my first step would be to jump the clutch safety switch and see what happens after that.
    96BlueTacos likes this.
  3. Jan 1, 2021 at 8:59 AM
    96BlueTacos
    96BlueTacos トヨダ
    Mikey
    Earth, 3rd planet from the Sun (CO)
    1996 Single Cab Taco Manual 4x4 3.4L V6 370k /1985 4Runner 4x4 22RE 200k /2001 Double Cab Taco Auto 4x4 Supercharged 3.4L V6 180k
    1996-JBA upper control arms, replaceable Cardan joint drive shaft, leveling kit, camper shell, trailer hitch... 2001- TRD Supercharged, TRD headers...
    Do you have a clutch cancel switch?
    If so put it in neutral, turn the key to the position before the engine cranks push the clutch cancel and try to start it. If no clutch cancel button, then I could only think to do what @Wyoming09 said and jump or bypass the button that the clutch pedal itself pushes and see what happens then go from there
  4. Jan 2, 2021 at 6:40 AM
    Wyoming09
    New Tripoli Pa
    Super Springs
    In neutral do you mean it cranks then quits or it starts then quits??
    Does the truck stall as you shift through neutral while driving or if in neutral while stopped ??
  5. Jan 3, 2021 at 3:04 AM
    Wyoming09
    New Tripoli Pa
    Super Springs
    Sure would be interesting to hear more about this???
