03 DblCab Rear End Swaying?!
Discussion in '1st Gen. Tacomas (1995-2004)' started by G59, Aug 31, 2017.
  1. Aug 31, 2017 at 11:11 AM
    G59
    G59 [OP] Stock af
    Torres
    SoCal
    03’ Long Travel DC
    Hello TC so I've had this problem for a while now and am not 100% sure on what the problem could be. I have a 2003 Taco double cab 3.4 with 5100s in the rear (no lift) and factory leaf springs. Tires are also 285/75/16 instead of factory 265s. Truck has 166k miles on it. What my problem is is that sometimes when I'm cruising at a decent speed (15mph+) and I hit a bump while turning (and sometimes while going straight, too) I can feel my whole rear end sway. (At least it feels like its my rear end.) Its usually not too bad but the other day I hit a bump on the fwy when turning on to another freeway going about ~50mph when my rear end swayed a pretty decent amount and almost caused me to lose control.
    What could be causing me this problem and what can I do to diagnose and fix it? I want to get this taken care of asap as my Taco is my daily driver and I would be devastated if I totalled it. :help:
    TLDR: Rear end is swaying when I hit bumps. What could be causing this problem?
  2. Aug 31, 2017 at 11:24 AM
    mechanicjon
    mechanicjon They call me "Jonny Stubs"
    Jon
    Scottsdale Arizona
    04 Taco SC 4dr SR5 TRD Prerunner
    Supercharged, AEM FIC/6, Meth Inj, ION Alloy's, Radio & Phone steering Wheel controls,Fabtech AAL, Billie's wrapped with 880's , Tundra big brake conversion, bully bars and Pioneer DDin Stereo/dvd with exterrnal usb ports. 290K and going strong.
    could be tires, tire pressure, weak springs
    G59[OP] likes this.
  3. Aug 31, 2017 at 2:32 PM
    G59
    G59 [OP] Stock af
    Torres
    SoCal
    03’ Long Travel DC
    You know what I checked my sway bar end links and the bushings are kind of ripped and the links move a bit when I try moving them around. Are they supposed to move or be super stiff?
  4. Aug 31, 2017 at 3:31 PM
    tony2018
    tony2018 Well-Known Member
    Did the 1st gen's come with rear swaybars stock?
  5. Aug 31, 2017 at 4:51 PM
    G59
    G59 [OP] Stock af
    Torres
    SoCal
    03’ Long Travel DC
    Unfortunately not; at least not the early 2000s 1st gens
  6. Aug 31, 2017 at 4:53 PM
    Clearwater Bill
    Billy
    Largo Florida
    Have you made sure you don't have a broken rear spring?
    The frame isn't rotted out is it?
  7. Aug 31, 2017 at 5:00 PM
    G59
    G59 [OP] Stock af
    Torres
    SoCal
    03’ Long Travel DC
    The frame is immaculate. The springs look good at first glance but ill give them a closer look. The leaf springs and their bushings are factory, and the springs do sag a bit
  8. Aug 31, 2017 at 5:19 PM
    tony2018
    I would check the leaf springs and rear shocks than.
