03 dies when put into gear: FIXED
Discussion in '1st Gen. Tacomas (1995-2004)' started by KOATacoma, Sep 5, 2019.
  1. Sep 5, 2019 at 9:01 PM
    KOATacoma
    KOATacoma [OP] Member
    2003 Red Tacoma TRD
    I have an 03 3.4 automatic. Today when my wife was turning into our drive she said it started "shaking". She said she turned it off after she parked.
    I went to check it out and it starts normally but as soon as I put it in either reverse or drive it immediately dies. It restarts a little harder than normal, like slightly flooded, but fine.
    I've tried setting parking brake and not using the service brakes, shifted t-case into low, shifting straight into manual 1 all with same results. With it in low range it did "lurch" before dying.
    I shifted the t-case into neutral and then shifted trans into gear, it didn't die.
    I'm fairly confident is a torque converter clutch lockup issue. The truck has 265,000 miles and don't think the fluid has ever been changed. It is slightly brown but can still see through it and no noticeable metal specks.
    Has anyone had this issue, any suggestions for diagnostics? I don't have easy access to a scanner and it's not going anywhere on it's own. As near as I can tell and from what I've been able to find the TCC solenoid is internal or I would start with changing it out.
    Thanks for reading all of this and in advance for any help/information.
  2. Sep 6, 2019 at 9:12 AM
    2003Tacoma4x4
    2003Tacoma4x4 New Member
    Nathan
    Reno, Nevada
    2003 Silver Tacoma Double Cab TRD 4x4
    2.5 lift with Bilstein 5100s. Rims and tires
    Maybe check the brake booster to see if it has a vacuum leak? You have step on the brake to put it in gear. The Diaphragm might be bad in the brake booster Start the truck and listen under the dash by the brake pedal. If you hear a hissing noise the booster is leaking.
  3. Sep 6, 2019 at 11:49 AM
    KOATacoma
    2003 Red Tacoma TRD
    I checked that by setting the park brake, putting it in neutral, start engine and put into gear without using the service brakes at all. It didn't change the results at all.
    From what I've found it looks like some have replaced the ECM, the solenoids or the torque converter. I feel it's less likely to be the TC as I would expect severely burnt fluid with a TC failure. I don't have much Toyota experience so was just hoping to hear from someone that has dealt with this issue before.
  4. Sep 6, 2019 at 12:17 PM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    Fatal_Paradox and CS_AR like this.
  5. Sep 6, 2019 at 7:58 PM
    KOATacoma
    2003 Red Tacoma TRD
    I had no idea they had something like that. I will be getting one soon.
    As for now, I'm going to check with AutoZone for the loan a tool program on my way home tonight.
    I don't recall any hesitation when revving in neutral/park, but I will double check that when I get home.
    jbrandt likes this.
  6. Sep 7, 2019 at 4:04 PM
    KOATacoma
    2003 Red Tacoma TRD
    No working scanner yet, if it's not one thing it's another...
    Confirmed, no hesitation when rev the engine in park or neutral.
  7. Sep 8, 2019 at 6:45 AM
    ElTaquitoJr
    ElTaquitoJr Well-Known Member
    01 Tacoma PreRunner 4 cyl
    Maybe something with the AIC valve? If you're good in park I think that would make sense because rpm usually changes when you shift into drive and reverse and the air and fuel mixture with it.
    Not a mechanic, just thinking out loud. Those things can get carbon buildup so when the air fuel mixture needs to change when going into gear, it hesitates and dies.
    Spark, timing and compression should be fine. Issues there would keep the truck from starting I believe. That leaves fuel and air.
    Hope you figure it out.
  8. Sep 8, 2019 at 6:53 AM
    fxntime
    fxntime Well-Known Member
    2015 Tacoma off road TRD and 2014 FJC
    Torque converter lockup isn't unlocking. It stalls because it's now acting exactly like a manual transmission would if you didn't have a working clutch and tried to ram the transmission into gear with the engine running. Instant stall.
    The engine shuddering your wife mentioned to you is a VG indication.
    Now you need to find out if it's an electrical issue or a mechanical issue causing the problem.
  9. Sep 11, 2019 at 8:43 PM
    KOATacoma
    2003 Red Tacoma TRD
    For a lack of simple diagnostics with what I have currently available I opted to order the solenoids and try replacing them. I should have them by Friday. Fingers crossed it fixes it and hopefully don't find a bunch of junk in the pan. Plan to drop the pan tomorrow so I'm ready once they arrive and may get lucky and they arrive tomorrow.
  10. Sep 12, 2019 at 6:54 AM
    osterhagen
    osterhagen Well-Known Member
    Rafe
    Glendale, AZ
    2003 DC v6, MTM, 4x4
    "Totally Stock"
    Hopefully that works out! Would suggest cleaning the magnets before reinstall. Also recommend Valvoline Max Life Synthetic ATF for replacement (replacement for type-4). I would also recommend changing out the filter while you are in there. Pays to only have to go in once. The factory sealant on the pan is pretty stout also and can take some work to get off. I used Timmah's video recommendation and cleaned mine up with a Dremel to get the old stuff off the pan. Used steel wool and brake cleaner for the trans side mounting surface.
    Looking forward to seeing if that resolves your issue. Good luck!
    Here is a link to the video - https://www.youtube.com/watch?v=tuGazNhuEtM&t=1526s
    Part number for the filter if you wanted to snag one - 35330-60030 (called a strainer)
    jammer likes this.
  11. Sep 18, 2019 at 3:12 PM
    KOATacoma
    2003 Red Tacoma TRD
    I used the AUTEX kit from Amazon. It included all 3 solenoid, filter and gasket. I also got the scan tool Jbrandt suggested.
    It was a fairly easy repair and I've got about 20 miles on it so far with no issues yet.
    I did replace all 3 solenoids and once finished I used just over 7qts of the Valvoline max life atf.
    Thank you to all who responded.
    ps, it can't be hard but I couldn't figure out how to put a simple link to the Amazon kit in here
  12. Sep 18, 2019 at 3:19 PM
    osterhagen
    Rafe
    Glendale, AZ
    "Totally Stock"
    Wow that is awesome! Glad you got it sorted. Hopefully many more trouble free miles ahead :)
  13. Sep 18, 2019 at 4:48 PM
    jbrandt
    Justin
    just copy and paste the link into the text box as if you're typing normally.
    Glad it's worked for you so far! I love this forum!
    otis24 likes this.
  14. Apr 15, 2024 at 10:24 PM
    K DUB
    K DUB Member
    oregon
    02 DC TRD 4x4 V6
    285/75 TOYO R/T on 16 alloys,k&n cold air intake, ARB bullbar, icon 2.5 w/ ccdv extended travel coilovers , icon upper control arms, tundra brake upgrade, Dakar leaf pack, greaseable shackles, wheeler's anti-sway kit, spydertrack wheel spacers 1.25",tranny cooler, IPF fog lights, LED headlights , rack it lumber rack, AIR lift airbags
    Hey @KOATacoma, how is the tranny holding up? My 02 double cab just started having this same issue, @ 307k, and last summer when changing the tranny fluid there were large chunks of metal and sludge.
  15. Apr 30, 2025 at 4:31 PM
    TashcomerTexas
    TashcomerTexas My truck is a whiner
    2003 TRD DC Supracharged
    Might be generating this issue.
    I can’t remember which code has occasionally popped up (normally I clear it with my ultra gauge plus and it’s g2g) (was some TC solenoid code). But I’ve always had an issue when switching from reverse to park or drive, more particularly when it’s hot outside.
    Moved my truck today and this time it stalled and died when I switched to drive. Parked and turned it off and was fine.
    Luckily enough I have a newer trans for my 4wd swap sitting and will probably do some surgery on the solenoids while it’s sitting.
  16. Apr 30, 2025 at 4:31 PM
    TashcomerTexas
    Great, helpful thread too! For a very niche problem.
