03 Double Cab roof rack removal
Discussion in '1st Gen. Tacomas (1995-2004)' started by justcuz, Jun 8, 2013.
  1. Jun 8, 2013 at 5:49 AM
    justcuz
    justcuz [OP] Well-Known Member
    is there a way of removing the factory roof rack
    from my 03 Double cab?
    will anyone be able to tell if it was ever installed after removal?
  2. Jun 8, 2013 at 6:56 AM
    TIPICOTACO
    TIPICOTACO Well-Known Member
    Tyler
    nw nj
    '01 DC 4X4 TRD "RAD BARON"
    Some lift, some armor, some scratches..
    my factory rack, a Perrycraft, is screwed directly into the roof's sheet metal so it would def be noticeable. I suspect the same applies to your rack..
  3. Nov 19, 2013 at 3:28 AM
    Edlo
    Edlo Member
    Ed
    Los Angeles
    Just a stock 4x4
    I'm curious why are you removing it, i'm thinking about putting on an OEM rack. Is it loud?
  4. Nov 19, 2013 at 6:34 AM
    Tribull
    Tribull Have more than you show. Speak less than you know.
    Little Rock, AR
    2015 Tacoma Double Cab 4x4 TSS Edition
    Bilstein 5100s with OME 887s and Dakars. SPC UCAs. 285/70R17 Falken Wild Peak A/T3W tires.
    If you do remove it, I will gladly buy it from you.
