03 Original Front Disk Pad Life?
Discussion in '4 Cylinder' started by joshhemming, Jul 11, 2011.
  1. Jul 11, 2011 at 3:26 PM
    joshhemming
    joshhemming [OP] Member
    Josh
    El Paso
    03 Tacoma SR5 2.4L Extended Cab
    My 2003 Tacoma 2.7L RWD Extended Cab has 51K miles. The brakes seem fine to me but during my last safety/emissions inspection the tech said he thought he heard some noise from the front brakes (he didn't pull the wheel to actually check them). He recommended I have them inspected at a brake shop.
    How many miles did you have when you replaced the original pads on YOUR Tacoma? Which usually wears out first....the front disk pads or the rear brake linings? I'm sure the individual driver's style affects pad/lining life but I'm just trying to get a ballpark figure.
  2. Jul 11, 2011 at 3:30 PM
    moto932
    moto932 What's the matter, Colonel Sandurz? CHICKEN?
    Eric
    Dayton, Ohio
    04 TRD Off Road SR5 Impulse Red
    5100's @ 1.25", Scangaugae II, deck plate mod w/AFE Pro Dry S filter, grey wire mod, alarm mod, defrost w/o compressor mod, de-badged, 17" sport wheels powder coated black, 1" B.O.R.A. wheel spacers, 265/70/17 Cooper Zeon LTZ's, sockmonkey beside decals.
    59k here, and still have some pretty good meat on them
  3. Jul 11, 2011 at 3:41 PM
    afd23a
    afd23a Well-Known Member
    The Dynamo of Dixie
    05 Access Cab 5 Lugger
    Factory Fog Lights, Removed Secondary Air Filter, Metra Ipod Adapter, Int Wiper Stalk, Wet Okole's, URD Short Shifter, Scanguage II w/Blendmount, Fat Bob's 2.75" spacer lift, ARE topper, SP Performance Pads & Slotted Rotors, 4.10 gears
    I've got an 05 and my front pads lasted to around 100k. The rear brake shoes should last much longer than the fronts. Most of the stopping power is done with front brakes so they will, and do wear out faster. It also really depends on your driving style. That's why there's no "replace your brake pads at xx miles".
