03 PreRunner Clock Spring Question
Discussion in '1st Gen. Tacomas (1995-2004)' started by RedRumble, Jul 23, 2010.
  1. Jul 23, 2010 at 8:41 PM
    RedRumble
    RedRumble [OP] Member
    North MS
    03 PreRunner SR5
    Clock Spring for 03 Tacoma
    I recently purchase a 03 Tacoma and the clock spring needs to be replaced. I thought I would look on ebay and I found some. One description states this:
    "Toyota Corolla Tacoma Drivers Side Airbag Clock Spring that came out of a 2001 toyota Tacoma. This Clock Spring is from a good car that has not been in a wreck. It has Not been turned over its limit either. It is the same clock spring used in the 2000 to 2004 Tacomas, some Mr2s, Celicas and a few of the 01, 02, Corollas too."
    This sounds legit, but what do you think? Just learning.
    Thanks,
    RedRumble
  2. Jul 23, 2010 at 8:46 PM
    Tacorunner87
    Tacorunner87 Well-Known Member
    Chino Hills Ca
    To much to list!
    Clock spring? Little more info on where it goes?
  3. Jul 24, 2010 at 6:14 AM
    RedRumble
    North MS
    03 PreRunner SR5
    The clock spring (spiral cable) is located in the stirring section under the horn/airbag section of the stirring wheel. My airbag light is on & the horn isn't working. From other post I've read the problem is the clock spring. I was just wondering if someone could verify the eBay description I posted in the original post.
    Thanks for the help.
  4. Jul 24, 2010 at 7:02 AM
    pairodice
    pairodice Well-Known Member
    Jay
    SF NM
    02 DCSB prerunner
    unless you knwo what you are doing dont mess with it my friend was installing a custom wheel in his civic had battery dsconnected for 30 min and still managed to set it off and break his wrist
    i wouldnt mess w/ used parts on stuff like that
  5. Jul 24, 2010 at 9:19 AM
    Tacorunner87
    Chino Hills Ca
    To much to list!
    If you mess with it If you remove the plastic around the column theres a yellow plug remove it so you dont have to worry about the airbag going off.
  6. Jul 26, 2010 at 5:12 PM
    Fortech
    Fortech Well-Known Member
    CANADA
    2005 Toyota Tacoma TRD OR
    Bilstein 5100's, rear TSB, Firestone bags
    The correct procedure is to remove the battery cable for several minutes, then pump the brakes several times. The SRS system is designed with a back up power source therefore you must wait at least 90 seconds with the key in the LOCK position for it to deplete itself. Pumping the brakes also helps rid the system of any charge.
