03 prerunner coil spacer lift
Discussion in 'Suspension' started by asdf, Oct 8, 2008.
  1. Oct 8, 2008 at 6:43 PM
    asdf
    asdf [OP] Well-Known Member
    Charleston, SC
    03 PreRunner
    3" in front, stock in back, 285/75/16 BFG KM2,5% tint all around, UWS black low profile, DTRL,line-X, deckplate...
  2. Oct 8, 2008 at 6:49 PM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    07 Silver4dr. 4x4, V6 Shortbed
    5% Tint, Bug flector, vent Visors, Removed secondary air filter, Rear Spring TSB w/ Wheeler's Add A Leaf HD Pack, Icon 2.0 rear shocks, Toytec 3" lift up front with Total Chaos UCA's, Debadged, Billet Grille,TRD Offroad rims/17x9 Pro comp 6001 rims, Duratracs 265/75/16 or 285/70/17, Fog light anytime mod, Tailgate hose clamp mod, Pro-dry AFE filter. Extended Differential Breather, ABS on/off, 6000k LEDs from CSJumper, heads/fogs, ScanguageII, Devil horns, Devil horns on third brake light, Mounted 60" Highlift, Mounted Tool Box, Wet Okole Front/Rear Seat Covers, TW sticker, Midland Handheld CB,Painted engine cover, Revenge Fab Sliders, ARE Topper, Weather tech Floorliners, Camper shell, ultimate headlight upgrade. URD -3° exhaust cam gears, .5" XTP Intake spacer. Custom dents.
    Metric tools I negelected to realise this. You should also go to autozone and get a coils spring compressor it should be free, 40 dollar deposit that you will get back on the return of the compressor. A friend would also make things easier.
