03 Starts hard
Discussion in '1st Gen. Tacomas (1995-2004)' started by klavoie, Dec 27, 2013.
  1. Dec 27, 2013 at 4:56 AM
    klavoie
    klavoie [OP] New Member
    Kyle
    New Hampshire
    03 Tacoma TRD
    265 Goodyear DuraTracs 2'' leveling kit
    Hi all, have an 03 Tacoma TRD that has trouble starting. When I turn the key it seems to crank fine but it will crank for a while before it starts up. Sometimes it seems to just barely start but it hasnt not started yet. Any ideas on what it could be? I havent had it looked at yet, although I have read on tacomaworld that it may be an o2 sensor? Is this common? Thanks in advance.
  2. Dec 27, 2013 at 5:12 AM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Once it starts, tap the MAF lightly with the handle of a screwdriver. If the idle fluctuates the MAF is bad.
    Other than that it could be a bad Coolant Temp Sensor or Air Intake Sensor, perhaps.
    If you have more than 130ish K I'd change the 02 sensor.
    Check the EGR is working correctly, it could be stuck open or closed.
    Look for dry, cracked or broken vacuum lines, too.
  3. Dec 27, 2013 at 8:09 AM
    JLee50
    JLee50 Well-Known Member
    Phoenix
    Stockish 99 4x4 TRD
    ToyTec coilovers
    O2 sensor shouldn't affect starting - you're not monitoring AFRs when the engine isn't running.
    How old are your plugs? Fuel filter? Does it run normally once it's started?
  4. Dec 28, 2013 at 6:46 AM
    klavoie
    Kyle
    New Hampshire
    03 Tacoma TRD
    not sure how old the plugs are or the fuel filter. I have only had the truck for a few months. It runs great once its started.
    I just read CE codes P0031 and P0446.
