03 Tacoma 2wd
Discussion in '1st Gen. Tacomas (1995-2004)' started by bgdeer1, Mar 14, 2010.
  1. Mar 14, 2010 at 1:57 PM
    bgdeer1
    bgdeer1 [OP] Well-Known Member
    minooka il
    tacoma prerunner
    3 inch lift in back 1 1/2 front. 31' mesa A/T's. Alpine deck, alpine speakers, l5 kicker solo baric sub
    I was woundering, i hear people who have 2wd complain about having "1 tire fire". and not having both tires spin.. I have that same problem. I was curious what the difference from posy and i hear some people use Lockers to fix the 1 tire to all 2 wheels spinning? can some on clarify?
  2. Mar 14, 2010 at 4:00 PM
    98_Mud_bug
    98_Mud_bug 98_mud_bug
    lucedale Ms.
    98 tacoma sr5/ 06 x-runner
    3 inch suspension lift, night shades corner and blinkers projector headlights with halos and 3 led's 18 inch kmc xd rockstar wheels,275/65/18 kelly safari tsr's, bush whacker fender flares 7 inch touch screen, 2 kenwood 12's, Magnaflow exaust single in dual out,
    lockers will fix it with a button, or a limited slip would help.
  3. Mar 14, 2010 at 5:16 PM
    bgdeer1
    minooka il
    tacoma prerunner
    so a locker will fix my 1 tire fire into a posi? or what. would i have to wire a button to engange and disengauge?
  4. Apr 8, 2010 at 7:09 AM
    Drewboto
    Drewboto Well-Known Member
    Drew
    Missouri
    Base model ಠ_ಠ
    17" Mustang wheels, Eclipse AVN 5435, Deck plate mod, vertical Maglite mount, K&N high-flow air filter, Delta gullwing box, amp, sub, 30 percent tint, floor lighting, tilt activated glove box lighting, lighting behind seat, engine bay lighting, SR5 grill surround, power windows, outside temp display
    I'm new here and may not know what I'm talking about but here is how I understand things...
    A locker is either electric or pneumatic and you'll need to wire a switch to urn it off and on. A locker isn't the same as positrac because a positrac system fits in your axle. It allows wheels to turn independantly for easy driving and turnng on pavement but will lock wheels together if it detects wheelspin.
    Locker kits are close to $1k while positrac is around $300
    somebody correct me if I'm wrong
  5. Apr 8, 2010 at 7:22 AM
    swdockter
    swdockter Well-Known Member
    Northwest Burbs, IL
    2" lift, 5100s, AAL, K&N, Deck Plate
    Ya, for the most part, you nailed it.
    Either option you choose will require you to change out the carrier in the pumpkin of the rearend. Not a job for the average Joe. ARB makes a nice locker that works off air pressure. You need an air pump with it.....around $1K+, not installed.
    You only need an ARB if you plan to do serious rock climbing....and with a 2 wheeler, that aint going to happen :) ...
    Go buy a posi setup and have it installed....or better yet, get a 4x4.
  6. Apr 8, 2010 at 7:45 AM
    STLharry
    STLharry Lube: It's the key to penetration.
    Harry
    VT
    Yeti Rescue Package with 270k miles
    '95-'97 camouflaged, ARB bull bar, RAT Products skid plate kit, sliders, Green Mountain Customs rear tube bumper and overland bed rack, King coilovers with Icon neoprene covers, defenestrated sway bar, OME Rear Suspension: CS046R leafs + AAL/5125 shocks/NWOR greasable hardware/U-bolt flip kit; S13WL Tundra calipers/pads/rotors, IPF H4 lenses and bulbs, IPF 968 DCG 100W lights, clapped out CB radio, Aussie-spec FJ60 inclinometer, ARB CKMA12 compressor, Superwinch S9000 with 12V Guy clock switch, 4' Hi-Lift, deckplate mod/grey wire mod/dif breather extensions, Duratrac tires, Sockmonkey bedside decals, boat cupholder, Dakine bike pad
    :D
    hahah
