03 Tacoma, "dead pedal" problem.
Discussion in 'Technical Chat' started by ghost5849, Feb 3, 2010.
  1. Feb 3, 2010 at 7:03 AM
    ghost5849
    ghost5849 [OP] New Member
    New Jersey
    2003 Tacoma 4X4 Double Cab TRD
    Stock
    I'm looking for an explaination to a recent problem I had with my 03 Tacoma 4x4 3.4L. The other night I was driving and stopped at a 4-way intersection. As I made a right turn and began to accellerate, I got a dead pedal. My truck idled fine and i was able to get the quarter mile home at a half mph. Pressing the gas pedal did nothing. I shutoff and restarted the truck but the problem persisted-the truck just remained at idle.
    The truck made no weird or unusual sounds prior to the incident and was driving fine up until that point. Today I had the time to try and fix the problem. I assumed I had snapped the throttle cable. An underhood inspection revealed the throttle cable is fine on both ends. I started the truck and it revved up. I put the truck in gear and it drove fine.
    This is baffling me. I need to know what caused this to happen so it doesn't happen again, possibly on the freeway or in a heavy traffic area. Here is some more information:
    Weather was cold, in the teens for several days.
    I had not driven the truck for the previous three days.
    The truck was warmed up. I had been driving approx ten miles.
    I am original owner and the truck has never had any serious mechanical problems before.
    Truck has 160k mi.
  2. Feb 3, 2010 at 7:08 AM
    98tacoma27
    Ben
    Not Beech Creek
    Since the cable is intact and I doubt it could"fix itself" if it came loose, it may be a fuel delivery issue.
  3. Feb 3, 2010 at 11:17 AM
    EnolaGaia
    EnolaGaia Well-Known Member
    Midwest USA
    '01 & '04 S-Runners
    01 SR: Double Cab conversion, S/C, lowered.
    2003 was the year they introduced throttle by wire. I'd start by checking the throttle position sensor.
  4. Feb 3, 2010 at 11:20 AM
    NAAC3TACO
    NAAC3TACO Middle aged member
    Just east of crazy, NV
    2014 SR5 DCLB 4x4
    Color matched door handles, Weathertech floor liners, bed mat, Durafit seat covers, tailgate clamp, 2016 TRD Sport 17" wheels with Yokohama Geolander AT tires , Toyota exhaust tip, Toyota/Yakima bike rail mount, Toyota wheel locks, Toyota hitch cover, Redline hood struts, unifilter on air pump.
    If you had water in the fuel it may have caused a fuel line freeze. I would put a couple of bottles of HEET in the tank and fill it up. That is if you can't find a problem with the throttle system.
  5. Feb 5, 2010 at 6:29 AM
    ghost5849
    New Jersey
    Stock
  6. Feb 5, 2010 at 6:38 AM
    98tacoma27
    Ben
    Not Beech Creek
    TPS may have hiccuped.
