03 tacoma/front 2.5" lift, new shocks question.. HELP!
Discussion in 'Suspension' started by will33, Nov 27, 2012.
  1. Nov 27, 2012 at 4:28 PM
    will33
    will33 [OP] Member
    will
    colorado
    k&n cold air intake, g-force computer chip, 2.5 " rough country lift, rancho 9000 series shocks, front custom bumper, rear rock crawler bumpers, piaa 3" fog lights
    On my 03 tacoma trd, I am in the process of installing rancho 9000 series shocks and a rough country 2.5 " lift. I finished the rear no problem. The front however, I ran into one problem only. After putting set together, I need another inch of space to fit bottom of shock into place. I tried the strut compressors, yet still did not gain enough space to install bottom of shock. Just a little more info., I have also disconnected sway bar or control arm. Could use some advice so I can stop looking at my beautiful truck wishing I was driving it. I will post pics of the truck when I return home. Thanks.
  2. Nov 27, 2012 at 9:19 PM
    520Toyota
    520Toyota Well-Known Member
    C.V.
    Nor Cal
    dcsb 6spd 4x4 offroad
    Ome lift
    Try popping off lower ball joint from the knuckle. That may give you the extra inch.
