03 Tacoma mods to increase power?
Discussion in 'Performance and Tuning' started by TKingsleyG, Jan 9, 2011.
  1. Jan 9, 2011 at 7:23 AM
    TKingsleyG
    TKingsleyG [OP] Member
    Trevor
    Mobile, AL
    03 Tacoma sr5
    I am the new owner of a 2003 tacoma 2 wheel drive sr5 and i would like to know if there are any engine mods out there or things i can do to beef up the power a bit that wont run in the 1,000's of dollars range. Just little things that will add some horsepower. If there arent any little things to beef it up, then what are the expensive things that will add the most power?
  2. Jan 9, 2011 at 2:15 PM
    LUSETACO
    LUSETACO Here for the Taco Pron
    Dennis
    Aim-ish country PA
    1999 Scooby Doo LGT 2008 P71
    Yes
    Search for deckplate mod. It's cheap and will add a few HP.
  3. Jan 9, 2011 at 2:29 PM
    Toyota Truck
    Toyota Truck Well-Known Member
    JT
    Texas
    2008 Prerunnner
    Magnaflow Muffler-TSB springs-Nuvi 265wt-aFe pro dry s filter-Husky Liners-Blue dome light-extra d-rings-OME 90000 sport struts-885 coils-N182 shocks-TSB AAL-LR UCAs-procomp black alloy rims- nitto terra grapplers-20% tint
    this and some headers, but dont expect much.
  4. Jan 10, 2011 at 8:47 AM
    Ridgerunner
    Ridgerunner Well-Known Member
    Frank
    San Francisco
    2001 prerunner doublecab limited
    2001 with; cat-back twin exhaust,elbow mod, Westin bullbar with Hella550's, Snugtop XTR camper shell, TRD off-road 2x4-black beauty.
  5. Jan 11, 2011 at 1:14 PM
    jcemitte
    jcemitte Livin' the taco life
    Jake
    Tulare CA
    04 Taco SR5 5 lugger
    Deck Plate mod, Knock Off Flowmaster,billet grill, alpine HU w/kicker amp and pheonix gold 12" sub stock componets
    im assuming you have the 2.4 liter motor with an automatic trans, and i have just the advice for you. turbo, or find a different truck. its a sad pesemistic point of view but its a reality i also must suffer as well. i got a aftermarket exaust and did the deckplate mod and it gave me a noticeable, but not substatial difference in mid range torque. there isnt much of the way in pep adding for our little truck because it wieghs about 3,150ish lbs and only has about 142ish hp assuming it hasnt lost any power since it was built.( which is more than likely the case ) ive since started pipe dreaming about a LC engineering 2rz tubo kit and started making my trucks audio and appearance, which is not my thing cause im in the mountains alot so until i can get a 4x4 taco or go up to the full size im just going to have to be content. sorry to burst your bubble.
