03 Tacoma prerunner antifreeze??
Discussion in '4 Cylinder' started by bgdeer1, Nov 24, 2010.
  1. Nov 24, 2010 at 7:27 AM
    bgdeer1
    bgdeer1 [OP] Well-Known Member
    minooka il
    tacoma prerunner
    3 inch lift in back 1 1/2 front. 31' mesa A/T's. Alpine deck, alpine speakers, l5 kicker solo baric sub
    Noticed my antifreeze was low.. Should I drain it and refill or just refill? I cannot recall the last time it was done since the truck was passed down to me.. And what type of coolant? I have some 50/50 blend .
  2. Nov 24, 2010 at 7:35 AM
    vr6pilot
    vr6pilot rather be dubbin'
    Dan
    Viva New Mexico!!
    2016 Quicksand SR5
    Did a quick scan of Yota Tech and it seems you can use any quality antifreeze. That does not, however, mean you can mix them. So, get more of whatever's in there (if you know) or do a complete flush-n-fill. Depending on mileage since last refill...might not be a bad idea.
  3. Nov 24, 2010 at 7:39 AM
    bgdeer1
    minooka il
    tacoma prerunner
    I had probably a cup of antifreeze left I'n my tank.. So I guess Im just gonna dump what I got I'n it n fill it up? Can u over fill?
  4. Nov 24, 2010 at 8:03 AM
    BeerHat
    BeerHat Got Beer?
    TX
    2001 PreRunner 4x4
    PreRunner 4x4, Homebrew Front Bumper, Homebrew Sliders, Homebrew Skids, Homebrew Bedbar, Homebrew Beer
    Are you referring to the white overflow canister in the engine bay? A cup is fine there. You have to pull off the radiator cap (do it when engine is cold!) to see what your coolant levels are and what color it is. If it is reddish in color, I would use the toyota red antifreeze. In addition, since you do not know when it was last changed, I would have the system flushed. From what it sounds like, I would have someone perform the service for you.
