03 Tacoma towing snowmobiles
Discussion in '1st Gen. Tacomas (1995-2004)' started by jInxx, Jan 26, 2016.
  1. Jan 26, 2016 at 9:34 AM
    jInxx
    jInxx [OP] Member
    Brent
    Massachusetts
    03 white Tacoma v6 4x4 manual
    So I have a clamb shell snowmobile trailer that can fit two sleds in it. I have only ever towed it once when I brought the sleds to my house, however now I will be going on a trip and will be towing them a pretty long distance. I am 22 and haven't had much experience towing anything so I was wondering if there were any tips or upgrades worth doing to ensure a safer or easier time. I read the very well put together post about towing that is on here however it said that the 1st gen trucks didn't come with a tow package and myne did so I'm a bit confused. I know it did because when I went to change the rear brakes I ran into a ton of problems getting the proper shoes for it as they are bigger on my truck.
    Some specs
    03 Tacoma
    v6
    4x4
    5 speed manual
    As I found out it has bigger breakes and also a bigger battery
  2. Jan 26, 2016 at 9:38 AM
    frizzman
    frizzman Well-Known Member
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    OME 2.5,Tundra 17s,Falken Wildpeak AT3W hitch w/ 7-pin, ARE cap, JVC HU w/BT, HID/LED lights
    you should be fine to tow. leave yourself a little extra distance for stopping.
    the "tow package" was a dealer installed option for 1st Gens. But that doesn't change the towing amount or habit, follow the guide and you're set
    edit: does your truck have the VSC (Vehicle Stability Control) option? those were slightly larger rotors (at least) but not sure about the rears
