03 Tacoma tube bumper build
Discussion in 'Technical Chat' started by 03TacoKeegan, Apr 12, 2016.
  1. Apr 12, 2016 at 8:24 PM
    03TacoKeegan
    03TacoKeegan [OP] Member
    keegan
    2003 White Tacoma SR5 4x4
    Grille guard, 100 Watt KC Daylighters, Pioneer double din radio, and black wheels.
    I have the choice of using 1 3/4" steel tubing or 2 1/2" rigid conduit to make a new bumper for my truck. First question is, which material would be better? I'm going to be using my truck as a daily driver and a weekend warrior once I lift her. Second question is where are the most important places to measure? I want to make a piece going along the bottom of the grille that has 4 bends in it, not sure where to put the bends or the degrees of the bends, I was thinking 60-75 on the two outer bends, and around 30 for each inside bend. Any help would be greatly appreciated. Thanks.
  2. Apr 16, 2016 at 6:41 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    It is your bumper and you have no idea what you want??
    Material Steel Tube What kind??? Could mean almost anything
    Want to use Conduit it is your bumper .
  3. Apr 16, 2016 at 6:56 AM
    03TacoKeegan
    keegan
    I'm just trying to get the measurement and the best material to use
    I'm just trying to get measurements and see what other people had used
  4. Apr 16, 2016 at 6:57 AM
    Clearwater Bill
    Billy
    Largo Florida
    I appreciate novice ingenuity. All of us have experienced a bit of that; it's how you move past novice.
    In this case, I'd suggest you get experienced help to guide you while you do the work. 'Cause you're clueless.
    I don't mean that in a demeaning way. But your material considerations are sketchy, you apparently don't know how to measure angles or prefab a build piece with templates and such.
    I won't say it's 'hard', but it requires careful work, abstract thinking and a bit of practice. Experienced hands can help that learning process immensely.
    No experienced hands around? Save your money and buy a pre built bumper that you'll have no fitment issues with.
  5. Apr 16, 2016 at 7:02 AM
    03TacoKeegan
    keegan
    My dad has
    My dad has quite a bit of experience, I am practicing bends with 2" conduit at the moment and I think 1 3/4" steel tubing that was left over from a roll cage would be more than enough. I also think 2 1/2" rigid conduit would be very strong and it cam definitely take an impact but its a little too thick. What would you use for material to build a bumper that would be better than my option? Willing to buy more materials but was trying to use leftover material and experiment a little bit.
  6. Apr 16, 2016 at 7:11 AM
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    1 3/4" mild steel (hrew) or DOM
  7. Apr 16, 2016 at 9:14 AM
    Wyoming09
    New Tripoli Pa
    Super Springs
    I need to ask you do have tube bender ?? That can bend DOM Tube ??
    If building a tube bumper it would be my first choice .
    You might want to do a little research into strength of materials just to get a idea what materials can be used for what.
