03 Tacoma Vibration Issue
Discussion in '1st Gen. Tacomas (1995-2004)' started by 03tacoma.2, Apr 10, 2017.
  1. Feb 11, 2018 at 1:23 PM
    drr
    drr Primary Prognosticator
    Dan
    Seattle-ish
    02 4WD Tacoma
    If the growl goes away when you engage 4wd, then it is almost certainly the front diff needle bearing.
  2. Feb 21, 2018 at 1:46 PM
    03tacoma.2
    03tacoma.2 [OP] Member
    Cole
    03 Tacoma TRD
    New Frame
    It has been officially diagnosed as the front diff needle bearing. You guys that have dealt with this issue what route did you take? Truck has 180k w/ new frame. My guess is a diff job is probably $1k+
  3. Feb 21, 2018 at 1:54 PM
    Willis_-8
    Willis_-8 Monkey With a Cold One
    Logan
    1998 White Tacoma TRD
    Well this just shit on my day. My truck is doing the same thing..
  4. Feb 21, 2018 at 2:09 PM
    drr
    Dan
    Seattle-ish
    02 4WD Tacoma
    I have not had to deal with replacing the needle bearing, but my understanding is that it’s not a terribly difficult job. There is a special tool needed, which there are a few of floating around since once you use it you don’t really need it anymore. I believe ECGS also sells them, along with the bushing you replace the needle bearing with.
    If you are mechanically inclined I would suggest looking into doing it yourself for a fraction of the cost.
  5. Feb 21, 2018 at 2:51 PM
    03tacoma.2
    Cole
    03 Tacoma TRD
    New Frame
    It is tempting to do a DIY. Anyone know of any good videos?
    I got my driveline fluids changed recently and they mentioned a few metal flakes in front diff fluid. Guess that was from the needle bearing failing? What happens if they aren’t replaced?
  6. Mar 3, 2018 at 8:44 AM
    03tacoma.2
    Cole
    03 Tacoma TRD
    New Frame
    Does anyone have the needle bearing removal tool for sale?
    whoareyou133 likes this.
