03 tacoma with 01 fuel tank? surprise
Discussion in '1st Gen. Tacomas (1995-2004)' started by talltimbers, Jun 8, 2020.
  1. Jun 8, 2020 at 5:33 PM
    talltimbers
    talltimbers [OP] New Member
    Andrew
    2003 tacoma 2.7L 4C extracab stock
    hey everyone,
    I just got my hands on a sweet 2003 tacoma with an awesome cap on the back for camping so i am very new here. the truck is awesome, however had a leaky fuel tank that would not pass inspection, and would only hold half a tank. I figured it would be easy enough to buy a new tank install it myself. I ordered a Spectra Premium TO31C tank which in theory is the right tank, however i was in for a surprise
    Today I decided to switch them out. i had the old tank off and was in the process of switching over some old parts and also was installing a new fuel pump. I realized that the fill vent was a different size on the old tank compared to the new tank.. at that point, i realized that the tanks were just a little bit different. it seems that the 2003 version has a tank valve vent while the 2001 tanks were the last ones that do not. Here i am thinking it was going to be a relatively quick fix (which never happens) that is turning into at least a few days while i wait for parts
    Should I try to buy the parts that would go to the 2003 tank? or should i return the 2003 tank and order a 2001 tank?
    Has anyone else had a similar experience where the parts that should be on one year are not there?
    I have to order some more parts regardless because the old tank was so rusted that some old parts straight up ripped off.
    cruiserguy and Black DOG Lila like this.
  2. Jun 8, 2020 at 5:45 PM
    Black DOG Lila
    Black DOG Lila Well-Known Member
    Virginia
    2003 Tacoma SR5 2.7 5 speed 4WD
    Stock. EZ pass.Dump pass.Inspection sticker.Convict printed lic.plates.FG cap.
    Welcome to TW Andrew
    Return the 2001 tank
    Replace your old 2003 tank with a new 2003 tank
  3. Jun 8, 2020 at 5:53 PM
    talltimbers
    Andrew
    Thanks Black Dog Lila,
    So I have the 2003 tank. it's the old tank that is a 2001. I was thinking about returning the new 2003 tank because i do not know if there are the right hoses for a tank vent valve.
  4. Jun 8, 2020 at 6:02 PM
    Black DOG Lila
    Virginia
    So you have a 2003 Tacoma with a 2001 tank?
    Is this a salvage title vehicle?
    I think you were sold the wrong tank.
  5. Jun 8, 2020 at 6:04 PM
    talltimbers
    Andrew
    yes. it was definitely a surprise.
    I am beginning to think that it is. I bought the truck from a friend, so a previous owner must have gotten a set up at a junk yard or something
  6. Jun 8, 2020 at 6:27 PM
    Black DOG Lila
    Virginia
    You specified Spectra T031A
    2003 tank is Spectra T031C
    OE #77001-04170
  7. Jun 8, 2020 at 6:45 PM
    talltimbers
    Andrew
    yes you're right there. i mistyped. the 01 tank is to31B. do you think it matters much that the tank valve vent might be missing?
  8. Jun 8, 2020 at 7:04 PM
    cruiserguy
    cruiserguy Well-Known Member
    Elijah
    SEKS
    2000 ext cab, 2.7L, auto, 4x4
    Yeah I'd think it would matter. The EVAP system is monitired by the ECU.
    Black DOG Lila likes this.
  9. Jun 8, 2020 at 7:06 PM
    cruiserguy
    Elijah
    SEKS
    That vacuum switching valve that you're saying..... Well hold up, I wonder if you could wire a resistor in place to manipulate the ECU from triggering the MIL, like folks do with O2 sensors and others
  10. Jun 8, 2020 at 7:06 PM
    Black DOG Lila
    Virginia
    Spectra T031B fits 2003 2wd
    Spectra T031C fits 2003 4wd
  11. Jun 8, 2020 at 7:10 PM
    Black DOG Lila
    Virginia
    Define "Might be missing" o_O:confused:
    Is it is or is it ain't?
  12. Jun 8, 2020 at 7:16 PM
    Black DOG Lila
    Virginia
    Oh lordy @cruiserguy
    I just can't wait for the whole upcoming EVAP Cannister, Purge Selnoid and tank pressure sensor text FIASCO:rofl::rofl::rofl:
    Wulf and cruiserguy like this.
  13. Jun 8, 2020 at 7:18 PM
    cruiserguy
    Elijah
    SEKS
    Dangit I wanna be laughing too! What am I missing here? Something went right over my head methinks :D
  14. Jun 8, 2020 at 7:26 PM
    Black DOG Lila
    Virginia
    OP got a 03 w/01 tank or vice versa
    And 03 or 01 or vice versa aftermarket tank to save $s and raninna prob with ABCs of Spectra T031 tankage.
    I need a nap
    Buh Bye :wave:
    cruiserguy[QUOTED] likes this.
  15. Jun 8, 2020 at 7:32 PM
    cruiserguy
    Elijah
    SEKS
    Oh I gotcha. Yeah unless it matches up to the original, I agree, he'll be in for a world of hurt
    So to keep it smart and simple, he should prolly go with the actual tank the track should have from the beginning. Assuming the electrical or venting wasn't modified...... Oh boy
  16. Jun 9, 2020 at 1:39 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    I hope Spectra got their quality control issues fixed. Baffle spot welds were cracking causing leaks.
    It is a Toyota 4x4 interesting things from other years are always found at the worst time in most cases .
    Go with the correct tank in this day parts are boxed wrong picked wrong ordered wrong.
    I am sure you could upgrade the Evap System to work might get expensive !!!
    Just get the correct tank to match what is in your truck
  17. Jun 9, 2020 at 8:13 AM
    tony2018
    tony2018 Well-Known Member
    forgive me for asking, but what changed from 02 to 03-04?
  18. Jun 9, 2020 at 3:47 PM
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
    If I remember correctly, 1995-2002 fuel tanks are completely different. The evap system is unique and the charcoal canister is moved from the engine bay, to under the bed. Therefore you have to use a 2003 or 2004 fuel tank.
    2WD 5-Lug fuel tanks are different too, If you’re a PreRunner 2WD you use the 4WD tank. There is like a three gallon difference in capacity, 15 gallons v. 18 gallons.
  19. Jun 9, 2020 at 8:37 PM
    tony2018
    my 02 has the canister near the tank.
    GQ7227 likes this.
  20. Jun 10, 2020 at 7:04 AM
    Black DOG Lila
    Virginia
    4 cyl 2.4. 2.7. or 6 cyl 3.4 ?:confused:
    Fill in specs on your profile :D:thumbsup:
