04' 3.4 starting issues.. Fuel problem?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Fishmoose, Feb 21, 2017.
  1. Feb 21, 2017 at 4:59 PM
    Fishmoose
    Fishmoose [OP] Active Member
    Jah Grove/ Costa Rica
    04' Tacoma v6 4x4
    First off I've only had the truck a few weeks and I've had this same symptom happen 3 different times.
    I was wiring a trailer light socket today and left the key in the on position for maybe 10 minutes. When I went to start it, it took a long time and eventually started.. Sputtering, and wanting to fall on its face but ran fine..
    Seemed like the cylinders were loaded with fuel and had a hard time burning it off.
    Is this common? All the other vehicles I've owned the fuel pump turns on a few seconds with the key on then shuts off until it's running.
    Please let me know if any of you have had this experience. Do I need to change a part?
    Thanks
  2. Feb 21, 2017 at 5:05 PM
    Jon G
    Jon G Hoarding Tacomas one at a time,
    Jon
    St John's Newfoundland Canada
    02, 04 & 07 Tacoma
    Magnaflow 2.5 Catback Exhaust K&N filter
    Check engine light on?
  3. Feb 21, 2017 at 5:11 PM
    Fishmoose
    04' Tacoma v6 4x4
    It does its initial light up then, NO lights when it's running.
  4. Feb 21, 2017 at 5:13 PM
    Jon G
    Jon
    02, 04 & 07 Tacoma
    How many km ?
  5. Feb 21, 2017 at 5:14 PM
    Jon G
    Jon
    02, 04 & 07 Tacoma
  6. Feb 21, 2017 at 5:16 PM
    Fishmoose
    04' Tacoma v6 4x4
    V6 and 83,000 miles
  7. Feb 21, 2017 at 6:52 PM
    ThunderOne
    ThunderOne Well-Known Member
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    You may have a leaking injector. Since the miles are so low, the seals could have gone bad if it sat for a long time
