04 DC new to me.
Discussion in '1st Gen. Tacomas (1995-2004)' started by Ronstafario, Mar 3, 2015.
  1. Mar 13, 2015 at 9:15 AM
    #41
    Ronstafario
    Ronstafario [OP] Member
    Florida
    '04 TRD Double cab
    I think you just want to argue. They came on a tacoma from the dealer and the only place to purchase these rims is at a toyota dealer. You call it what you will, but that's what I call stock. It's just semantics and there's zero reasons to argue about it. Especially on a new members very first post. You gave me a bad impression about this whole forum. Good job guy, did you prove your point....
  2. Mar 13, 2015 at 9:49 AM
    #42
    frizzman
    frizzman Well-Known Member
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    OME 2.5,Tundra 17s,Falken Wildpeak AT3W hitch w/ 7-pin, ARE cap, JVC HU w/BT, HID/LED lights
    In actuality they came on the 05-06 Tundra DC XSP models (southern states option, us northerners didn't get it) and look good on them due to their size.
    use a small spacer but due to the width you may need to eliminate the mudflaps.
    I've always liked these wheels and told myself if I moved to Tundra I'd get them. "For me" I like the 17" versions of the Toyota wheels as no mods are required :)
  3. Mar 13, 2015 at 9:57 AM
    #43
    Taco gator
    Taco gator Taco with 6.5" front 0" rear lift
    J.D.
    Lakeland, FL
    2014 2wd Taco
    6.5" Spindle/5100 lift front lift
    They also had a Tacoma version of it. And yes it is an Southeast Toyota distributed package. So it only is available in the southeastern states.
    I'm pretty sure the wheels are put on the truck before the truck is sent to the dealerships. You an only get the wheels if you buy the whole package. They aren't a single option.
  4. Mar 13, 2015 at 6:09 PM
    #44
    stumpman
    stumpman Well-Known Member
    tn
    2019 Dclb cement
    It's all good OP, I never bashed your wheels, did not have the answer to your question, I did question you regarding them being factory wheels, that's why many are here to learn, sorry you took offense, but you obviously do not understand the difference between dealer add-on, regional distrubutor or factory installed. You referenced TW members in a negative way regarding your truck not being lifted or 4wd, for that I take offense, no where on this forum does a TW forum member say you should die, muchless all of them as you stated. So interpreting what TW members are posting is obviously difficult for you to understand to say the least!
  5. Mar 14, 2015 at 5:43 AM
    #45
    stumpman
    tn
    2019 Dclb cement
    OP you ask " did I prove my point?" Yes, my point is you cannot fix stupid, I tried!
