04 engine has a strange problem
Discussion in '1st Gen. Tacomas (1995-2004)' started by choopes, Jul 3, 2025.
  1. Jul 3, 2025 at 10:21 AM
    choopes
    choopes [OP] Well-Known Member
    Troy, Al.
    2004 reg cab
    Stock
    My 2.4 four cylinder runs just fine when its cold. After it warms up, the engine wants to die. There is a sweet spot on the throttle that will get me back home. Very small. A little more then a idle. Any more, or less throttle, and it dies. I think this is thermal related, and likely ignition. Fuel pressure is good. Throttle body sensor looks good. That is to say, a smooth advancement as the accelerator is pushed. The only code I get relates to the knock sensor. There are 2 temp sending units. I thought about changing them. The one on the back of the head concerns me.
    Before I start throwing parts at it, like a blind man throwing darts in a dark room, Has anyone seen this before?
    Thanks
  2. Jul 3, 2025 at 11:19 AM
    Glamisman
    Glamisman Well-Known Member
    Maybe... IIRC, yours is a drive by wire throttle, anyway, what he did was turn the key on and slowly press the acceleator pedal to the floor 3 times, it is worth a shot
  3. Jul 3, 2025 at 2:24 PM
    ControlCar
    ControlCar My Moto: Help & Learn…period.
    Steven
    Sugar Land TX
    1996 Taco 2.4L 2wd Automatic
    Clock Volt meter/LSPV Delete/Hyundai 16’s/FP gauge/after 9months of wrenching ZERO oil leaks
    any codes popping?
  4. Jul 3, 2025 at 2:31 PM
    ControlCar
    Steven
    Sugar Land TX
  5. Jul 3, 2025 at 2:39 PM
    choopes
    Troy, Al.
    2004 reg cab
    Stock
    Knock senser. I ordered a new one.
    t0p_d0g and ControlCar[QUOTED] like this.
