04 frame rust
Discussion in '1st Gen. Tacomas (1995-2004)' started by Zurovetz, Sep 18, 2019.
  1. Sep 20, 2019 at 7:38 AM
    Tacowaco
    Tacowaco Well-Known Member
    Tallahassee, FL
    02 Tacoma Double Cab 4x4
    This is a tough question, I looked at those. If you have the space and skill, I'd find a frame (I found one on Craigslist for $500 when I was looking), clean it up and rustproof it, then switch over your truck onto it. It doesn't look like rocket science, just alot of work:
    https://www.youtube.com/watch?v=Urqq8FbVvb0&t=503s
    det107 and GQ7227 like this.
  2. Sep 20, 2019 at 7:40 AM
    frizzman
    frizzman Well-Known Member
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    OME 2.5,Tundra 17s,Falken Wildpeak AT3W hitch w/ 7-pin, ARE cap, JVC HU w/BT, HID/LED lights
    it's 5 months past his 15 year warranty... he didn't say it was treated
    Safe-T-Cap would just be a band-aid at this point, you are correct that it would just get worse over time
    GQ7227[QUOTED] likes this.
  3. Sep 20, 2019 at 7:46 AM
    MagtechPA
    MagtechPA Thor
    Pittsburgh, PA
    That's a beautiful truck, hope you can find a way to save it.
  4. Sep 20, 2019 at 7:47 AM
    frizzman
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    it's not a "recall" so be careful on the terms. it was a "technical service bulletin (TSB)" for frame rust issue.
    unless you were in or registered in a "cold weather" state the goop spray was not required
  5. Sep 20, 2019 at 7:49 AM
    frizzman
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    also, unless it was a left-over lot truck the last production was August for the 1st Gen. Chances are everything is moot when considering checking VINs anymore. sorry @Zurovetz but I hope you can find a replacement frame. chances are it's going to be cheaper in the long run to do a full swap.
  6. Sep 20, 2019 at 7:56 AM
    GQ7227
    GQ7227 mw survivor
    J A Y
    good to know you do not necessarily have to remove engine and transmission!
  7. Sep 20, 2019 at 8:56 AM
    cruxofthebisquit
    cruxofthebisquit Well-Known Member
    Orange Texas
    2000 TRD
    OME and worth every penny.
    I'd try fighting with them some about the date. Does suck you've had it sitting around from the date it expired. That was a 10K dollar decision.
    04Pre_Runner likes this.
  8. Oct 20, 2019 at 8:42 AM
    markum
    markum Active Member
    01 4x4 double cab TRD, m37, 69 W-200 Power Wagon
  9. Oct 20, 2019 at 9:01 AM
    Wsidr1
    Wsidr1 Well-Known Member
    Indiana
    2 x 95.5 Ext 2.7L & 3.4L A/T 4x4
    That's a tough spot to to repair without removing the cab. Plus, it looks like there's nothing left to weld to even if you could access it. So, Safe-T-Caps may not do you any good.
    How widespread on the frame is the problem? Looks like your rear bumper is sagging. Is that also from frame deterioration?
    GQ7227 likes this.
  10. Oct 20, 2019 at 7:30 PM
    Zurovetz
    Zurovetz [OP] Member
    No, backed into something and pulled it back as best I could. That’s the only spot that’s very bad externally, I’m afraid if I started trying to weld on the frame I’d blow giant holes in it
