'04 Overhaul (Operation: Blanco Taco)
Discussion in '1st Gen. Builds (1995-2004)' started by TacoS805, Mar 7, 2018.
  1. Mar 7, 2018 at 2:47 PM
    TacoS805
    TacoS805 [OP] Well-Known Member
    So Cal
    2004 White 2.7L 4x4 5 speed Xtra Cab
    Hey Everyone,
    So like the title says, I'm overhauling my '04 that I purchased recently to get it to as close as new as possible condition.
    I've combed thru the forums quite a bit, and given some of the symptoms my truck has, I know it has front end/steering issues, the shocks are toast, leafs are pretty tired, and the clutch is a bit little rough. I want to get all of this stuff dealt with before really altering it too much.
    My truck is also 4x4, so I am open to any recommendations on things that would be a good idea to inspect/replace as for as 4x4 components.
    Preliminary:
    Intake Air Filter Replace (Done)
    Spark Plug Replace (Done)
    Inspect MAF (Done)
    Inspect Throttle Plate (Done)​
    Phase I:
    Steering rack & pinion
    Steering rack bushings
    Inner tie rods
    Outer tie rods
    Shocks all around
    Front shock bushings
    Strut Mount
    Upper ball joins
    Lower Ball Joints​
    Phase II (Starting the fun stuff):
    Line-x
    Hitch
    Rear Bumper w/ Tire and gas can rack
    Shell OR Tonneau cover / rack for storage box, bikes, boards, etc.
    Largest KO2s I can get w/o lift
    Bluetooth Stereo​
    Thanks for looking!
    Will upload photos as progress is made!
