04 prerunner front brakes
Discussion in 'Performance and Tuning' started by Chopper84, Jan 9, 2013.
  1. Jan 9, 2013 at 8:02 PM
    Chopper84
    Chopper84 [OP] Keep Trucking
    Brian
    North East Las Vegas
    04 Tacoma Prerunner SR5 2wd
    Cb radio in dash, Aftermarket Alpine head deck, Seat covers, Dual Air horn from autozone, Tinted windows.
    Wanting to buy some drilled and slotted rotors next time i have to do my breaks. my question is would it be worth it long term as i live in vegas with plenty of dirt to hit and will mid travel the truck most likely.
    OR should i get a better rotor then normal and better pads?
    any opinions on both ideas?
  2. Jan 10, 2013 at 12:37 AM
    Justus
    Justus fucks not given
    Nabisco the kid
    In ur toolbox
    stockish
    Drilled rotors can crack........some slotted can pulse amd chew up pads.
    Id suggest brembo blanks and hawk lts pads, or if u must use a fancy rotor use a slotted one and not a drilled one.
    Do more homework on who makes good slotted rotors if u go that route......id bet brembo slots are decent
  3. Jan 10, 2013 at 10:57 AM
    chris66
    chris66 ( ͡°( ͡° ͜ʖ( ͡° ͜ʖ ͡°)ʖ ͡°) ͡°)
    dust
    CO
    2004 Prerunner
    bfg at ko2, method double standard
    whats the situation with the rear brakes... i think the majority of the braking is done with the fronts so is it even worth converting from drums?
  4. Jan 11, 2013 at 4:52 PM
    Chopper84
    Brian
    wasnt planning to change rears really. more just the front brakes. id only do rears after its paid off and i do the mid-long travel set up. but thats like 20 years price and time frame
  5. Jan 12, 2013 at 1:20 AM
    Justus
    Nabisco the kid
    In ur toolbox
    stockish
    Do lots more homework.......I know the kits for 2nd gens (rear disc conversion) make braking WORSE. Im not sure about 1st gen kits tho......just try a quality rotor and pad up front first since that's a large amount of ur braking anyhow
  6. Jan 12, 2013 at 1:26 AM
    zbaldo
    zbaldo Well-Known Member
    Ozzy
    Torrance, Ca
    99 4Runner SR5 4X4
    Stock as Stock can be with duratracs and a roof rack
    There is also the tundra brake swap a decent amount of work and you have to have the 16" wheel to clear the caliper but its supposed to give the best brake performance that is available for first gen tacomas.
    You would have to swap rotors and calipers and get new pads.
    Not sure about brake boosters as I don't know much about them but I've seen people talk about those on the forums.
    If you want to go budget and not too fancy but still getting an upgrade get the blanks and pads. Thats what I plan to do when I have to swap my pads and if I have the extra cash.
    I forgot to mention cryogenic rotors but they are expensive they are supposed to be more heat resistant than regular rotors and fade less I believe.
    You may be able to get some more performance by draining your current oil and replacing it, so I've read.
  7. Jan 12, 2013 at 1:28 AM
    zbaldo
    Ozzy
    Torrance, Ca
    99 4Runner SR5 4X4
    There is no point to do rears on these trucks. There are only a couple of swaps and they pretty much suck for the value.
  8. Jan 12, 2013 at 7:31 AM
    Chopper84
    Brian
    again the rears are only a thought when the truck is paid and if i long travel or mid travel the truck. and the fronts are the idea for when the rotors are toast for the ones i currently have. which means it will be awhile. ive heard the drilled and slotted are good but i dont know if offroad conditions will decrease that. mainly heard from street vehicles about use and what not.
  9. Jan 12, 2013 at 7:40 AM
    Torspd
    Torspd Tor-nication
    Tor
    Houston
    MMVI 4.4L 4x4 Access Cab
    Torspd Custom Turbo kit [] Borg Warner 9180EFR Turbo [] ProEFI Pro128 EMS [] TiAL Q BOV [] TiAL V44 Wastegate @ 15psi [] CP Pistons [] CP Carrillo Rods [] ARP Head studs [] ARP Main Studs [] ARP Header - Head Studs [] Ported Heads w/ 1mm oversized valves intake/exhaust [] Brian Crower Forged Stroker Crank [] Darton M.I.D. Sleeved Block [] Kelford Camshafts [] Torspd 170* T-stat mod [] APR Large Fuel Rail [] Aeromotive Stealth 340 LPH Fuel Pump [] FueLab FPR [] APR T56 Conversion Kit [] KP RACING Built T56 [] McLeod Racing Custom Twin Disk Clutch [] One Piece Aluminum Driveshaft [] MGW Shifter [] Custom lowering kit [] Ohlins Front Coilovers [] QA1rear shocks [] Custom Ron Davis Radiator [] Dual SPAL Electric Fans []
    This is what I have heard as well too. www.TundraRacing.com sells a rear conversion for the second gen. I believe that it is the rear setup from a 4Runner. OEM parts, and meant for a 4000 lb + vehicle. Yet our weight distribution is highly biased towards the front, versus the 4Runner.
    Also, they have a different proportioning system and brake booster. Which levels their all wheel disk braking. Our Tacomas need an adjustable proportioning valve so that you can properly setup the rear braking force. Otherwise it will be too much after bolting on.
    Get the adjustable valve, and set it up. Then they would be a great addition. Not the easiest job, but I know one who has done it.
