04 Tac leaking gear oil
Discussion in '1st Gen. Tacomas (1995-2004)' started by Hornbejr190, Apr 18, 2016.
  1. Apr 18, 2016 at 4:40 AM
    Hornbejr190
    Hornbejr190 [OP] Active Member
    hey guys before I bring it to the shop I wanted to get some opinions on what needs to be done. My 04 Tacoma 6 cylinder 4x4 is leaking gear oil from where the drive shaft (not sure that's the right term) meets the pumpkin. Wondering if this is going to be a big fix or if there's a seal there that went bad? It's a sonewhat slow leak and I'm keeping the pumpkin filled. Trucks got 150,000 on it. Thank you!
  2. Apr 18, 2016 at 8:36 AM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    That's called the pinion seal and it may be cheaper to keep topping it up. But always worth it to see if someone will do it for a reasonable price.
