04 Taco 6cyl TPS adjustment?
Discussion in '1st Gen. Tacomas (1995-2004)' started by HawaiianBrian, Sep 14, 2010.
  1. Sep 14, 2010 at 8:40 PM
    HawaiianBrian
    HawaiianBrian [OP] Member
    Big Island
    04 Xtra Cad TRD 4x4
    I just replaced my TPS and now my engine doesn't respond to the pedal until the pedal is almost to the floor...it should respond right away. Am I missing something? Is there an adjustment you can make to the TPS?
    I made sure to position the new one exactly like the old one. Obviously I'm not a mechanic, but I'm broke and unemployed and need my truck.
    Any help is greatly appreciated!!!
  2. Sep 15, 2010 at 7:32 AM
    crazyasu45
    crazyasu45 Well-Known Member
    Canada
    2013 MGM DCLB 4X4 TRD SPORT
    3" SUSPENSION LIFT
    How did u know ur TPS was bad?
  3. Sep 16, 2010 at 12:05 AM
    HawaiianBrian
    Big Island
    04 Xtra Cad TRD 4x4
    I didn't think this post worked, I've posted another thread: Here's that post...
    My 04 Tacoma 6 cyl(5VZ-FE) has been having issues. I noticed a intermittent
    lack of response from the engine when pressing the gas pedal.
    Retrieved Error Codes:
    p2135 throttle/pedal/pos a/b voltage correlation
    p0122 A low input
    p0123 A High input
    p0222 B Low input
    p0120 A circuit
    Purchased an installed new TPS, cleared codes, reset ECM.
    Check Engine light still on. Read codes again, same codes.
    Now I don't get response from throttle until pedal is almost to the floor. When I manually move the accelerator cable there is a bunch of movement in the cable before the throttle replies.
    I had a local mech look at it before I got into it...he said I needed a new throttle body...seemed a bit drastic to me so I wanted to look at it myself.
    Any Ideas?
  4. Sep 16, 2010 at 6:55 AM
    EnolaGaia
    EnolaGaia Well-Known Member
    Midwest USA
    '01 & '04 S-Runners
    01 SR: Double Cab conversion, S/C, lowered.
    Did you check the accelerator (pedal) position sensor?
