04 Tacoma Front Suspension Noises
Discussion in '1st Gen. Tacomas (1995-2004)' started by JCK, Jun 22, 2019.
  1. Jun 22, 2019 at 9:45 AM
    JCK
    JCK [OP] Member
    2004 Tacoma 4x4 extra Cab V6 TRD
    3' Bilstien Lift - stock springs
    Hello all - My Taco's making some loud clicking/clanking noises. Front end - both sides. Happens when there's upward travel, sharp bumps, sudden incline at speed etc. Thoughts?
    Area51Runner likes this.
  2. Jun 22, 2019 at 9:53 AM
    Masshole_And_His_Taco
    Masshole_And_His_Taco RIP Rick
    Northish South Shore MA
    Two-seater Curb-eater
    Little bit of stuff.
    For rattles over bumps, my first suspect is always the sway bar links. Nothing else seems obvious to me, but I gotta hand it to you OP. This is single handedly the best video I've seen from someone looking for help diagnosing. Props!
    Edit: Although I'm not sure if there is supposed to be that kind of flex in the shock towers seen in your top -down view
    JCK[OP] and Prayn4surf like this.
  3. Jun 22, 2019 at 9:55 AM
    Prayn4surf
    Prayn4surf 20 minutes late
    Socal
    2004 Tacoma xtra cab
    Welcome to TW!
    I have no clue what that could be, hopefully someone can chime in who has had that same noise. I would check the entire suspension, look at the welds on the shock towers for cracks, look for loose bolts, and check your ball joints. If there is any play in your ball joints they are toast. But what @Masshole_And_His_Taco said makes sense. Def props on the vid.
  4. Jun 22, 2019 at 3:07 PM
    JCK
    JCK [OP] Member
    Thanks Masshole_And_His_Taco and Prayn4surf - I figure I should be as thorough as possible before asking for advice. Video is super helpful. Sway bar is on the list - I hear there's a factory torque value for this - ill let you know if it sorts the issue. I agree with the movement in the shock towers - it looks sloppy to me. I'm going to check out the strut mount welds as well.
    Masshole_And_His_Taco likes this.
  5. Jun 22, 2019 at 3:15 PM
    Glamisman
    Glamisman Well-Known Member
    I think I can see a little slop in the lower ball joint at apx 24 seconds. What I an looking at is the gap between the offset of the ball joint arm and the joint itself with the rim as the backdrop... it looks like there is a slight hesitation between when the assembly starts to rebound and the joint itself starts to react... if that makes any sense... then again I have been wrong before.
  6. Jun 22, 2019 at 11:21 PM
    homegrown_xt
    homegrown_xt Well-Known Member
    Sonoma County
    1996 Tacoma Xcab 4x4 V6 MTM
    Rancho Quick lift. Wheelers Off Road Progressive AAL with Rancho RS9000's, braided brake lines & clutch line. BFG 32x11.50 15 All Terrain Tires Deck Plate Mod. Flowmaster 60 series muffler and Marlin Crawler Short Throw Shifter.
    Are those new front shocks? It could be the top hats on top of the shocks. They have bearings that wear out over time.
