04 to 97 rear axle question
Discussion in '1st Gen. Tacomas (1995-2004)' started by Ryanjkyle13, Jun 28, 2023.
  1. Jun 28, 2023 at 3:43 PM
    Ryanjkyle13
    Ryanjkyle13 [OP] Member
    2000 Tacoma & 96 4runner
    What’s up TW. I’m normally able to find all the answers to my questions on here just by searching but can’t seem to find much regarding this.
    I currently have a bone stock 1997 4x4 and have an opportunity to grab a whole elocker rear axle and re-geared differentials (front and rear) off of a 2004; along with all the other suspension components both front and rear.
    Trying to figure out what trouble I might run into if I do this swap.
    I know the brake line setups and the internals of the drum brakes are different between the 95-00 and the 01-04 rear ends. But that should be fine since I’d be swapping everything and not just the housing?
    Mostly wanting to know about the leaf setups. I believe the springs from the 95-97 are slightly shorter than later years. Will the spring perches on this 04 line up and work fine? And would I have to order new 95-97 specific springs or would I be able to use these 04 springs?
    Any help would be greatly appreciated!
    1997tacomav6 likes this.
  2. Jun 28, 2023 at 3:59 PM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    How much fabrication do you want to do??
    new springs for your 95-97 would just be a replacement .
    The 04 you would need to move the spring hangers . Without looking I no longer remember just how much or if the shackles need moved.
  3. Jun 28, 2023 at 4:03 PM
    eon_blue
    Azusa, CA
    You can't use the 04 leaf springs unless you relocate your spring hangars on your frame...the 04 ones are longer. I would just get new ones for the 95.5 - 97 model year. As far as I know there's no difference in the perch on the housing, it's just where the hangar is mounted on the frames that's different
  4. Jun 29, 2023 at 7:13 AM
    old grouch
    old grouch Well-Known Member
    Stan
    Colorado Springs, CO
    95 4x4 V6 Extra Cab
    E-Locker SS Skid 2" Lift
    I can confirm this. I did the same swap. Straight bolt on.
    Ryanjkyle13[OP] likes this.
