SOLD - 04 Toyota Tacoma Long Travel Supercharged 4x4
Discussion in '1st Gen Tacomas For Sale (1995-2004)' started by jberry813, Oct 7, 2016.
Thread Status:
Not open for further replies.
  1. Oct 7, 2016 at 9:22 AM
    jberry813
    jberry813 [OP] Professional Fluffer Moderator
    Lake Tahoe
    2012 DCSB Sport
    ...too much shit to list.
    Alright, lets try to keep the chatter to a minimum here. It's time to move on to the next build, so this one is going up for sale.
    I built this truck with the goal of doing pretty much anything and everything I wanted...and doing it well. It's built to handle high speed wide open desert, but has the right equipment to crawl almost any of your favorite trails, or to take off for a week in desolation. It's been through the Rubicon, Slick Rock, Deer Valley, Signal Peak, Niagra Rim, Hell Hole, Dusy/Ershim, you name it. It's also been through almost of the favorite trails in Moab, Ocotillo Wells, Superstition, Anza Borrego, Barstow, Lucerne, Mojave, Joshua Tree, Salton Sea, Oceano Dunes, Oregon Dunes, too many to list. This truck is NOT a pavement princess. If you're looking for a scratch and chip free truck, this isn't the right truck for you. There are brush pinstripes and rock chips in the paint and wheels. If you're looking for a street legal daily driveable rig that is ready to hit the trail, read on.
    This truck was the main feature in 4Wheel & Off-Road magazine September 2016. Web article: http://www.fourwheeler.com/features/this-2004-toyota-tacoma-owner-has-his-cake-and-eats-it-too/
    2004 Toyota Tacoma TRD Xtra Cab
    3.4L V6 (5VZ)
    4x4 with 5 Speed Manual (R150F)
    79,xxx Miles
    Performance:
    TRD Supercharger
    URD 7th Injector Kit with Tunable Piggyback Controller
    URD 2.2 SuperGrip Supercharger Pulley
    URD Short Shifter
    Auto Meter Boost Gauge in A-Pillar Mount
    AFE Intake with Dry Filter and Prefilter
    Magnaflow 18" Muffler and custom cat-back
    Walbro 190 LPH Fuel Pump
    Regeared to 4.56
    Die Hard Platinum (Odyssey) Battery Relocated to the Bed
    ARB High Performance Air Compressor (CKMA12) with Tire Inflation Kit
    Bonzen Engine Mounts
    4X Innovations Transmission Mount
    LCE Pro Clutch Kit
    LCE Heavy 30 Pound Flywheel
    Every Suspension & Shock Bolt Replaced with Either F911 or Grade 8 Bolts
    ABS Delete
    EBC Slotted Rotors
    EBC Yellow Brake Pads
    Stuff in the Front:
    Total Chaos +3.5" Long Travel Kit
    Extended Stainless Steel Brake Lines
    Total Chaos Limit Straps
    2.5x8" King Coilovers (currently valved for crawling, but I can help you valve them however you want)
    Total Chaos Secondary Shock Hoops
    1" Diff Drop
    Total Chaos Heim Steering (1" solid stock with double sheer mount and 3/4" Heims)
    Total Chaos Cam Tab Gussets
    Total Chaos Coil Bucket Gussets
    Total Chaos Spindle Gussets
    Total Chaos Steering Rack Bushings
    ARB Air Locker
    Modified First Gen Tundra CV axles with Bates Porsche 930 CV Boots
    Stuff in the Rear:
    Custom King 2.5x16" Double Bypasses (compression tube is a pure race tube)
    Fabricated Bed Cage
    Fox 2x4" Stroke Hydro Bumps (Shortened to 2" Stroke)
    All Pro 50T Spring Pack (62" Leaf Pack Spring Under)
    All Pro Extended Stainless Steel Brake Line
    12" Fabricated Shackles above the frame
    Total Chaos Shackle Pivots and Pivot Gussets
    Total Chaos Lower Shock Mounts
    First Gen Tundra 8.4 Complete Rear Axle
    ARB Air Locker
    @RelentlessFab Axle Truss
    Currie U-bolt Bash Plates
    5/8" U-bolts
    Trail Gear 6 Ply Limit Straps
    Wilwood Brake Proportioning Valve
    Shoes:
    @SCSPerformance F-5 16x8 Wheels
    Hankook Dynapro MT 285/75/16 Tires
    Lights:
    LED Hi/Low Headlights
    42" Curved LED Roof Light Bar (Spot Beam Pattern)
    @RelentlessFab Low Profile LED Roof Mounts
    20" LED Driving Light (Double Row Combo Beam Pattern)
    20" Amber LED Fog/Dust light (Single Row Combo Beam Pattern)
    Blitzpro Amber Rear Dust Lights on a ShowMe Flasher
    Spyder One Piece Headlights
    LED Rock Lights
    Blue Sea Power Distribution Block
    Exterior Goodies:
    Glassworks Fenders and Bedsides
    Glassworks Supercharger Hood with Scoop
    @RelentlessFab Custom Front Bumper
    @RelentlessFab Custom Bumper and IFS/Mid Skid
    Demello Sliders
    BudBuilt Crossmember and Bellypan/Transmission/Transfer Case Skid
    TRD Gas Tank Skid
    Fabricated Rear Bumper Tied into Bedcage and Frame
    Fabricated Dual Vertical Spare Tire and 2 Ton Aluminum Floor Jack
    Heavy Duty Axle Straps to Retain the Spare Tires
    Trail Gear Frame Plates
    Trail Gear Frame Box Kit
    Two 5 Gallon NATO Gas Cans with Mounts Built into BedCage
    Slide-in Bed Cage Adapter for Snowboard Rack, Safari Basket, Bicycles, Roof Top Tent, Kayaks, whatever you need to carry
    Kobalt Slim Toolbox
    Harbor Freight 2 Ton Aluminum Floor Jack with @RelentlessFab Aluminum Skid Plate
    Interior Goodies:
    Pioneer Navigation
    JL Audio Monoblock Amp
    2 JL Audio 10" Subs
    OTRATTW Rocker Switches
    WeatherTech FloorLiner Mats
    Homelink Install in Headliner
    Uniden PRO520XL 40-Channel CB Radio with External Speaker, External PA, and Quick Disconnect 2' and 4' Firestick Antennas
    Harness wired up for Tekonsha Trailer Brake Controllers
    Compustar 2 Way Alarm with Glass break sensor, 2 stage shock sensor, sliding rear window sensor, and RPS knock sensor
    DEI 1 touch window roll up/down and auto roll up when alarm is armed
    Recent Maintenance:
    Brand new Toyota OEM Lower Ball Joints with Double Sheer Mount for Tie Rod Ends (Installed May 2016)
    Brand new Total Chaos Bushings in Upper and Lower Control Arms (Installed May 2016)
    Clutch, Flywheel, Pressure Plate, Pilot Bearing, & Throw-out Bearing (Installed September 2016)
    Coilovers Rebuilt (May 2016)
    Mobil 1 5w/30 Synthetic and OEM Toyota Oil Filter every 3000 miles
    New OEM Calipers, EBC Rotors and EBC Pads (Installed July 2016)
    Spare Parts Included with the Truck:
    2 brand new Moog lower ball joints (driver and passenger)
    Used factory soft rear brake line
    2 used OEM Toyota lower ball joints with double sheer mounts for heim steering
    Original front bump stops
    4 used fuel injectors
    Used pinion flange
    Brand new Walbro 190 LPH fuel pump
    Brand new OEM Toyota rear main seal
    Brand new OEM Toyota front axle seals (driver and passenger)
    Used spare 5/8" u-bolts
    Used spare engine accessory belts
    Used supercharger tensioner pulley/assembly
    2 brand new inner tie rod ends
    Original used engine mounts (block side...not including rubber isolators)
    Original used transmission mount
    Original used supercharger pulley
    Factory air box and plumbing
    Brand new OEM Toyota air filter
    2 used front spindle/wheel bearing assembly (passenger and driver)
    2 brand new total chaos spindle gussets
    2 used spindle dust caps
    2 used front differential mount cushions/isolators
    Used AFR sensor
    Factory intake manifold
    6 used Denso iridium spark plugs
    6 used NGK spark plugs (for non-supercharged)
    Used spare throttle body
    1 spare OEM Toyota CV completely assembled
    1 spare OEM Toyota CV (needs inner and outer boots and grease repack)
    2 spare aftermarket CVs
    1 spare Toyota inner CV assembled
    1 spare Toyota outer CV(needs CV cage, birf, and bearings)
    1 spare used complete front driveshaft
    1 spare used front driveshaft up to the slip yoke (no flange on one side)
    Original front diff carrier (removed for ARB carrier/locker)
    SOLD
    Not interested in any trades of any kind.
    No I will not part any of it out. No I will not sell any of the spare parts separately. Package deal.
    If the deal is right, I'm willing to tow it a "reasonable" distance.
  2. Oct 7, 2016 at 9:28 AM
    eon_blue
    Azusa, CA
    :eek: :drool::drool::drool:
    Good luck with your sale, but I doubt you're going to need it
    45acp, dtaco06 and jberry813[OP] like this.
  3. Oct 7, 2016 at 9:58 AM
    Large
    Large Red
    So many rigs up for sale now
  4. Oct 7, 2016 at 9:58 AM
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    Sad to see it go :/ but whoever gets this is getting a bulletproof rig that can go anywhere :bananadance:
    jberry813[OP] likes this.
  5. Oct 7, 2016 at 10:01 AM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    Let's hope so!
    4runner is getting a little more love. ADS shocks and sliders for the moment.
    The 2nd gen is getting the real love.
    I removed one from the pile.
    :thumbsup:
    big_jarv and dtaco06[QUOTED] like this.
  6. Oct 7, 2016 at 10:07 AM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    I bought @AaronArf's rig.
    cmack and dtaco06[QUOTED] like this.
  7. Oct 7, 2016 at 12:28 PM
    SconnieHailer
    SconnieHailer PutterClutch
    Marc
    West Central Wisconsin
    2012 TRD Off Road Double Cab V6 6Speed
    Good luck with the sale!
  8. Oct 7, 2016 at 12:40 PM
    Whitecloud
    Whitecloud Cloudy-fabricator of things
    Johnathan
    Albuquerque, New Mexico
    Superwhite 06 DCLB
    ICON Extended travel Coilovers, Custom leaf pack, custom sliders and F&R bumpers, 295 75 17 Toyo Open Country MT's, On-Board air with F+R connectors, On-Board water with quick disconnect shower.Trimmed fenders and body mount chop. LOTS of wiring, dual battery setup, Solar charging system, with some random lights spread around here and there.
    GLWS Sad to see it go.
  9. Oct 7, 2016 at 1:43 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Farewell you beast of a truck. What an inspiration.
    New owner better appreciate this shit
    AaronArf and jberry813[OP] like this.
  10. Oct 7, 2016 at 2:36 PM
    T-Rex266
    T-Rex266 SpaceX Director Moderator
    Elon
  11. Oct 8, 2016 at 1:00 PM
    DIRT YOTA
    DIRT YOTA Aka EL ROJO
    Cory
    Camarillo, CA
    03' dbl cab with some stuff
  12. Oct 11, 2016 at 3:54 PM
    White317
    White317 New Member
    Auston
    Is this truck still for sale
  13. Oct 11, 2016 at 5:16 PM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    Yes
  14. Oct 11, 2016 at 5:23 PM
    White317
    White317 New Member
    Auston
    Will you take 17000 cash next Thursday?
  15. Oct 11, 2016 at 6:32 PM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    I sent you a PM.
  16. Oct 17, 2016 at 2:50 PM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
  17. Oct 18, 2016 at 1:12 PM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    SOLD
    DIRT YOTA and T-Rex266 like this.
  18. Oct 18, 2016 at 1:13 PM
    T4RFTMFW
    T4RFTMFW Well-Known Member
Thread Status:
