04 toyota tacoma problem
Discussion in '1st Gen. Tacomas (1995-2004)' started by fish, Oct 30, 2008.
  1. Oct 30, 2008 at 7:55 AM
    fish
    fish [OP] fish
    winter garden,fl
    04 tacoma 4x4 4 door
    4'' procomp suspenchin lift 33x12.50x17 procomp x terrans and procomp wheels
    i have a problem when i am driving down the road about 30 -40 mph and i hit the brakes right before it stops there is like a pretty big bump like it is in the trans mount or the carrier bearing have ya'll guys ever heard of anything like this.:confused:
  2. Oct 30, 2008 at 8:05 AM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    07 Silver4dr. 4x4, V6 Shortbed
    5% Tint, Bug flector, vent Visors, Removed secondary air filter, Rear Spring TSB w/ Wheeler's Add A Leaf HD Pack, Icon 2.0 rear shocks, Toytec 3" lift up front with Total Chaos UCA's, Debadged, Billet Grille,TRD Offroad rims/17x9 Pro comp 6001 rims, Duratracs 265/75/16 or 285/70/17, Fog light anytime mod, Tailgate hose clamp mod, Pro-dry AFE filter. Extended Differential Breather, ABS on/off, 6000k LEDs from CSJumper, heads/fogs, ScanguageII, Devil horns, Devil horns on third brake light, Mounted 60" Highlift, Mounted Tool Box, Wet Okole Front/Rear Seat Covers, TW sticker, Midland Handheld CB,Painted engine cover, Revenge Fab Sliders, ARE Topper, Weather tech Floorliners, Camper shell, ultimate headlight upgrade. URD -3° exhaust cam gears, .5" XTP Intake spacer. Custom dents.
    Are you hitting the breaks hard or just under normal use? Also does it happen all the time? Does your brake pedal feel like it is pushing back up, if so your abs is acting up.
  3. Oct 30, 2008 at 8:05 AM
    HerNameIsLucy
    HerNameIsLucy I miss Lucy. :-(
    Equador. Don't know why.
    RIP Lucy.
    She's gone but not forgotten.
    could be severe axle wrap
  4. Oct 30, 2008 at 8:32 AM
    fish
    fish [OP] fish
    winter garden,fl
    Braking under normal use and happen's most of the time toyota said it is carrier bearing i can get under the truck and wiggle the drive shaft were the carrier bearing is it wiggles a little bit.
  5. Oct 30, 2008 at 8:34 AM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    There you go change your hanger bearing.
  6. Oct 30, 2008 at 8:40 AM
    fish
    fish [OP] fish
    winter garden,fl
    Is the carrier bearing going to have a little bit of play or is that not right or could it be axle wrap?
  7. Oct 30, 2008 at 8:44 AM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    axle wrap....guaranteed. either get new leaf springs, or get a cheap set of helper springs........that will take care of the problem. something you can do to lessen it though..............take the 4 bolts out that hold the drive shaft slide yoke to the rear diff......clean out all the old grease and any corrosion(i sanded mine down to get rid of the rust) and put some antiseize on it, slide and bolt back together and then regrease it. next, i installed new leaf springs, and now i have zero axle wrap.
  8. Oct 30, 2008 at 11:38 AM
    SRFIVE
    SRFIVE Well-Known Member
    Upstate NY
    '09 SR5 AC
    Automatic transmission, right? Does it happen immediately when you hit the brakes, or only just before you physically stop? If it is the latter, I agree with Tacomaman06, 99.99% chance it is axle wrap. When I added the AAL, it went away.
  9. Oct 31, 2008 at 10:23 AM
    tacoma2002
    tacoma2002 Member
    Pacific Northwest
    Tacoma 4x4 TRD
    2.5" OME suspension lift 3" body lift canopy fog lights/brush guard
    Regarding the axle wrap problem: I have re-greased my driveshaft splines (especially the rear ones) and the problem went away, but came back after a month or so. I have been hesitant to beef up the leaf springs because I have a smooth ride. I am wondering: has anyone fixed the axle wrap problem with beefier leaf springs without compromising the smooth ride?
  10. Oct 31, 2008 at 10:37 AM
    SRFIVE
    Upstate NY
    '09 SR5 AC
    I like the ride I have, by just adding the 4 pack AAL, plus I can load up the bed now. The ride is fine (it's a truck). I still have a ever so slight lurch or thunk (as it has been called on the boards) every once in a while. I heard a one piece driveshaft has helped some too...I think that's worth considering also?
  11. Oct 31, 2008 at 11:07 AM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    i added wheelers 5 pack rear leafs....1.5 inches of rear lift, and the ride is smooth as silk man, but firm at the same time, if that makes any sense.
  12. Oct 31, 2008 at 11:23 AM
    fish
    fish [OP] fish
    winter garden,fl
    thanks guy ya'll have been a huge help THANKS AGAIN!!!!!!
