0420 Code
Discussion in '1st Gen. Tacomas (1995-2004)' started by KGcoffee, Oct 28, 2024.
  1. Oct 28, 2024 at 9:40 AM
    KGcoffee
    KGcoffee [OP] Member
    kyle
    03 tacoma
    Hi all,
    I had a 0420 (catalytic converter bank 1 ) Code . In fact the check engine light was on for over 2 years or so, but I knew what it was. I changed out the converter this weekend. It was stalling out on me. I thought I was in the clear and it was running great for a bit, but now it is stalling again and the Check Engine came back on. The upper O2 sensor is relatively new , 2 years or so and I did not change it.
    You tube is telling me it may be a Mass Air flow sensor or a Throttle position sensor.
    Any thoughts are appreciated.
    KG
    HondaGM likes this.
  2. Oct 28, 2024 at 9:53 AM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    Any codes stored now...
  3. Oct 28, 2024 at 9:53 AM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Stay away from any YouTube that “suggest or tells you change parts”.
    To know for sure. You need to graph the upstream and downstream sensors.
    If you want to YouTube anything, watch videos on diagnosing P0420/430 codes.
    BTW, the chance it being a MAF is very low.
    Test, don’t guess.
    KGcoffee[OP] and HondaGM like this.
  4. Oct 28, 2024 at 12:36 PM
    Glamisman
    Glamisman Well-Known Member
    And to add onto the above, use both year make model and OBDII generic when looking at "live" data. Sometimes the data you are looking at is stored/calculated values as opposed to true live data.
  5. Oct 28, 2024 at 3:58 PM
    ztwatson
    ztwatson Well-Known Member
    Milwaukee, WI
    2004 Tacoma TRD Xtra Cab
    My P0420 code was from a small leak between the rear CAT and the rear O2 sensor. Once I got it welded up the code went away.
  6. Oct 28, 2024 at 4:14 PM
    ControlCar
    ControlCar My Moto: Help & Learn…period.
    Steven
    Sugar Land TX
    1996 Taco 2.4L 2wd Automatic
    Clock Volt meter/LSPV Delete/Hyundai 16’s/FP gauge/after 9months of wrenching ZERO oil leaks
    Zwatson on to something…….
