'05/'06 Tacoma Head Gasket Failure Poll
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Fitz235, Feb 28, 2019.
Have you had the head gasket fail on your '05/'06 Tacoma?
  1. I have an '05/'06 and my head gasket failed
    17.7%
  2. I have an '05/'06 and my head gasket has NOT failed, I'm above 140,000 miles
    33.9%
  3. I have an '05/'06 and my head gasket has NOT failed, I'm below 140,000 miles
    25.8%
  4. I have an '05/'06 and my head gasket has NOT failed, I'm above 200,000 miles
    22.5%
  1. Mar 1, 2019 at 12:51 PM
    #41
    Hans Moleman
    Hans Moleman Well-Known Member
    Bay Area, CA
    2023 F-150 Powerboost
    You all should put your build dates. The build date is on the sticker on the driver side door jamb. Apparently the ones built before 12/2005 have the bad head gaskets. So that's why early 2006's have bad head gaskets.
    Mine is 2006 built 1/2006. No problems yet. 80k miles.
    N-C.nebulosus and Fitz235[OP] like this.
  2. Mar 1, 2019 at 12:54 PM
    #42
    Boogyman
    Boogyman Well-Known Member
    Phoenix
    Corpus Christi, TX
    2022 Lunar Rock Trail Edition
    Stay up on maintenance and do it all yourself so you know it’s done lol I don’t drive it gingerly either
    Weissenheimer and Rsmallw2 like this.
  3. Mar 1, 2019 at 12:55 PM
    #43
    Masshole_And_His_Taco
    Masshole_And_His_Taco RIP Rick
    Northish South Shore MA
    Two-seater Curb-eater
    Little bit of stuff.
    Mine was built 10/05, but no issues yet at 268k so... maybe I'm lucky for once?
  4. Mar 1, 2019 at 1:01 PM
    #44
    Fitz235
    Fitz235 [OP] Well-Known Member
    Rob
    New Hampshire
    Black '22 DCSB TRD Offroad 4WD
    - TRD T4R Pro Wheels - TRD Lift Kit - TRD Skid Plate - 265/70/17 Toyo Open Country 3's - OEM Bed Lights - OEM Bed mat - Alpharex Tail Lights - TacomaBeast LED Interior Lights - Green Lane Offroad Aluminum Sliders - Place Holder for More Bad Financial Decisions...
    Great point.
    Mine is definitely in the problem range (12/04). I bought mine in Feb. '05.
  5. Mar 1, 2019 at 1:04 PM
    #45
    Fitz235
    Rob
    New Hampshire
    According to the date range posted earlier, you may have gotten one of the first of the re-designed HG's.
    Or one of the last bad ones...
    In either case, 268k on that motor is already a success story.
  6. Mar 1, 2019 at 1:06 PM
    #46
    So mine is dated 10/05, any more specific method of finding which design my truck got?
  7. Mar 1, 2019 at 1:08 PM
    #47
    Very true, but I plan on putting at least another 200k on her. No plans to ever get rid of her, maybe just relieve her of duty as my DD.
    Fitz235[QUOTED][OP] likes this.
  8. Mar 1, 2019 at 1:10 PM
    #48
    I'm currently engaged in a race to 300k with my family. My 06, Dad's 04 Taco w/ 269k, sister's 03 4Runner with 236ish, and Mom's 01 Land Crusher with 284k. Let's just say we like our Yota's.
    Rsmallw2, R0dzilla75 and Fitz235[OP] like this.
  9. Mar 1, 2019 at 1:12 PM
    #49
    blu92in99
    blu92in99 Hates everyone, equally
    Justin
    Elk Grove, Ca
    Short of removing the heads and physically inspecting the gaskets you have, against a set of the updated design? No.
  10. Mar 1, 2019 at 1:13 PM
    #50
    *Begrudgingly adds that to the already very long list of things to do*
  11. Mar 1, 2019 at 1:54 PM
    #51
    Boogyman
    Phoenix
    Corpus Christi, TX
    Just went out to check lol 04/06 so I got the redesigned head gasket
    Masshole_And_His_Taco likes this.
  12. Mar 1, 2019 at 2:29 PM
    #52
    Lester Lugnut
    Lester Lugnut Well-Known Member
    N of Mex-S of Canada-E of LA-W of NC
    '15 Tacoma PreRunner V6 SR5 Auto
    A typo I'm sure, but you might want to change it for new arrivals who are not up to speed on this issue.
  13. Mar 1, 2019 at 3:04 PM
    #53
    BadDogMax
    BadDogMax Well-Known Member
    IdahoLand
    2019 TRD Pro
    Mine failed at 260k. Very slight leak
  14. Mar 1, 2019 at 4:30 PM
    #54
    Hans Moleman
    Bay Area, CA
    Yup, thanks:oops:
  15. Mar 1, 2019 at 4:36 PM
    #55
    PzTank
    PzTank Stuck in the Well
    Above the Notches
    ‘15 AC SR5 4X4 4.0 Auto
    ‘07 OR leather shift knob
    From what I’ve read, don’t let them overheat ever...
  16. Mar 1, 2019 at 4:37 PM
    #56
    MARSHBUSTER
    MARSHBUSTER Well-Known Member
    Jim
    Alamogordo NM
    2005 SR5 4X4 Tacoma TRD
    Grill Gaurd/ Winch Bumper, Mile Marker 9000 LBS Winch, Custom Head Ache Rack, Custom Rear Bumper, Marathon Camo Max 4 Seat Covers
    Not always, Mine had none of those signs.
  17. Mar 1, 2019 at 4:49 PM
    #57
    MARSHBUSTER
    Jim
    Alamogordo NM
    Mine failed around 137,000 miles, A very small leak in the left side gasket. After having it repaired I now have over 200,000 miles and its runs like a brand new truck.
  18. Mar 1, 2019 at 5:04 PM
    #58
    Dirt
    Dirt Well-Known Member
    Ross
    Brentwood
    rosscmuirhead@gmail.com
    Can you elaborate on your failure and diagnosis
  19. Mar 1, 2019 at 5:28 PM
    #59
    MARSHBUSTER
    Jim
    Alamogordo NM
    Every once in awhile after driving home from work in the evening (45 minute drive) I would hear boiling in the overflow bottle. Temp gauge would be reading normal. I started building a white crusty material around the cap for the overflow bottle. I went and talked to a mechanic I know about this after about 6 months. We used the Bubble test first, Take the cap off of the radiator, Start the truck, Look in the radiator and watch for bubbles, If you have bubbles you have a problem. Yes I had bubbles. Then we used the Blue fluid tester and it turned green. Yes it turned green. He also said the white crusty material is what lead him to believe I had a problem to begin with. So, If you think you have a problem, Make sure your radiator is full, Take the cap off, Start the truck, Look into the radiator, Watch for small bubbles, Give it a little bit of time. Good Luck!!!
  20. Mar 2, 2019 at 10:43 AM
    #60
    Weissenheimer
    Weissenheimer Well-Known Member
    Bryan
    Southern Maine
    05 TRD O/R (desert sand mica)
    FN FX wheels, Dobinsons suspension, air bags, other bells and whistles
    I have a February built 2005. Bought from original owner meticulously maintained at 89k. Currently at 103k and no issues. I actually wasn't aware of this issue when I bought it...but hey you can't always have it all haha
