'05/'06 Tacoma Head Gasket Failure Poll
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Fitz235, Feb 28, 2019.
Have you had the head gasket fail on your '05/'06 Tacoma?
  1. I have an '05/'06 and my head gasket failed
    17.7%
  2. I have an '05/'06 and my head gasket has NOT failed, I'm above 140,000 miles
    33.9%
  3. I have an '05/'06 and my head gasket has NOT failed, I'm below 140,000 miles
    25.8%
  4. I have an '05/'06 and my head gasket has NOT failed, I'm above 200,000 miles
    22.5%
  1. Oct 12, 2022 at 7:45 AM
    #141
    thehesher
    thehesher Well-Known Member
    sorry to bring that anxiety back! I know what you’re talking about. I’ve actually been wanting an FWC for a while now, and throwing around the same question between getting a tundra for it or trying to outfit my tacoma. Unfortunately I can’t answer on work with head gasket issue year anymore because apparently mine was made outside that range. But I do hope that your trip is successful and problem free!
  2. Oct 12, 2022 at 10:03 AM
    #142
    Stelcom66
    Stelcom66 Well-Known Member
    2007 2.7L 5MT 4WD
    Sorry if I missed it - I didn't look at every single post but I wonder if this situation applies to a specific engine? When I was looking at 4Runners a while back I heard the same 2005-06 years with the same V6 engine as the Tacoma had some tendencies to have head gasket trouble. I've seen a couple reports of head gasket failures with the 2.7L, but I believe more with the V6.
  3. Oct 12, 2022 at 1:09 PM
    #143
    JasonLee
    JasonLee Hello? I'm a truck.
    Q322+3C Denver, Colorado
    15 TRD OffRoad
    TRD Supercharger and more.
    I believe this is specific to the (single) VVTI 1GR-FE, not any of the “high output” dual-VVTI 1GR. I forget when the 4Runner switched to that.
    I think there is a separate thread(s) for the 2.7L.
  4. Oct 12, 2022 at 2:05 PM
    #144
    Weissenheimer
    Weissenheimer Well-Known Member
    Bryan
    Southern Maine
    05 TRD O/R (desert sand mica)
    FN FX wheels, Dobinsons suspension, air bags, other bells and whistles
    As far as pushing my motor goes, I will be sure to update this thread if anything happens between now and after my road trip in (May ‘23). I also run my camper for weekend ski trips so I’ll be testing this truck all winter lol. For the current moment I will do a combustion gas test when the kit arrives and will update on that too
    JasonLee likes this.
  5. Oct 12, 2022 at 7:31 PM
    #145
    MARSHBUSTER
    MARSHBUSTER Well-Known Member
    Jim
    Alamogordo NM
    2005 SR5 4X4 Tacoma TRD
    Grill Gaurd/ Winch Bumper, Mile Marker 9000 LBS Winch, Custom Head Ache Rack, Custom Rear Bumper, Marathon Camo Max 4 Seat Covers
    You don't have to wait for that. Take your radiator cap off, Start the truck, Look into the radiator and watch for bubbles, If you see little bubbles coming up out of your radiator where the cap should be you have a Head Gasket Issue, Ask Me How I know, That is the Exhaust Gasses escaping through your radiator.
  6. Oct 13, 2022 at 12:35 PM
    #146
    point45
    point45 Well-Known Member
    SoCal, OC
    05 DCSB TRD offroad
    When mine started to go the tester I had would not detect the gasses in the coolant but an oil test showed trace amounts of coolant in the oil.
    yeahdude97 and Fitz235[OP] like this.
  7. Oct 16, 2022 at 5:20 PM
    #147
    yeahdude97
    yeahdude97 Well-Known Member
    Thats what mine did as well. Blackstone labs showed trace amounts of coolant in the oil, but everything else looked fine
  8. Oct 16, 2022 at 5:46 PM
    #148
    Weissenheimer
    Bryan
    Southern Maine
    I will try that. Do I need to warm up the truck with the cap off first? I would think this test won't work until the thermostat opens?
    So at that point, did you get your head gaskets done? Or did you keep running it? I have zero signs of issue and block test passed. I’ll do a Blackstone test next. But I’m at a crossroads here, assuming that test passes too…I’m at the point where I need to stop overthinking it and enjoy my truck, or cop out and get rid of it in fear something could happen
  9. Oct 16, 2022 at 6:35 PM
    #149
    MARSHBUSTER
    Jim
    Alamogordo NM
    It will work with the engine cold or warm, The Exhaust gasses need to go somewhere.
  10. Oct 16, 2022 at 8:25 PM
    #150
    sybiotesrage
    sybiotesrage New Member
    Kyle
    2005 white TRD Off Road
    None yet
    I don't see what the big deal is, I've changed head gaskets on my cherokee 4.0 and also on my 96 bronco with the 5.8. I've never had and issue with them after replacing them, always and I mean ALWAYS take the heads to the machine shop to get milled and cleaned always gives you a great surface to work with along with new head bolts of course
  11. Oct 16, 2022 at 8:38 PM
    #151
    point45
    SoCal, OC
    05 DCSB TRD offroad
    I changed mine because of coolant loss.
    normal day to day driving no problems, go up some steep mountain roads and it would start spitting coolant.
    I take my truck camping in the middle of no where. I do not want it breaking down on something I could fix beforehand.
    Weissenheimer[QUOTED] likes this.
  12. Oct 16, 2022 at 8:56 PM
    #152
    yeahdude97
    I haven't done anything yet... it still drives fine, has never overheated. I'm thinking of getting the gasket and water pump replaced. Blackstone said everything looked excellent minus the coolant and i'm at 227k miles. I'd rather take my chances rebuilding my engine versus putting in an unknown junkyard engine
  13. Oct 17, 2022 at 4:29 AM
    #153
    Weissenheimer
    Bryan
    Southern Maine
    This last page of info has been very helpful everyone. Always good to hear the different scenarios and what people ended up doing (or not doing). It at least makes me feel better about running it for now. And maybe a little less frantic about the whole situation. What's that thing people say when you practically "webMD" yourself to death lol
    Dan 77 likes this.
  14. Oct 17, 2022 at 12:52 PM
    #154
    MARSHBUSTER
    Jim
    Alamogordo NM
    Mine drove fine and never over heated. One thing I would notice, When I had the heater on I would have good heat until I came to a red light and had to stop, The heat would get cold until I would get moving again. I also had Bubbling in my coolant bottle 3 or 4 times in about a years time. It didn't matter if I drove the truck for an hour or six hours when that would happen. My head Gaskets went around 136,000 to 139,000 miles.
  15. Oct 17, 2022 at 2:43 PM
    #155
    Stelcom66
    2007 2.7L 5MT 4WD
    What engine is yours?
  16. Oct 17, 2022 at 2:49 PM
    #156
    MARSHBUSTER
    Jim
    Alamogordo NM
    I have a 2005 with the 4.0
  17. Oct 17, 2022 at 3:17 PM
    #157
    Stelcom66
    2007 2.7L 5MT 4WD
    Hopefully now it'll be fine for 100k+ miles.
    MARSHBUSTER[QUOTED] likes this.
  18. Oct 17, 2022 at 4:03 PM
    #158
    MARSHBUSTER
    Jim
    Alamogordo NM
    Since the work was done I am sitting just under 250,000 miles and she is running like a new truck.
    Weissenheimer likes this.
  19. Oct 17, 2022 at 4:58 PM
    #159
    Stelcom66
    2007 2.7L 5MT 4WD
    Good deal! I should not have assumed the repair was done recently.
  20. Oct 17, 2022 at 5:05 PM
    #160
    MARSHBUSTER
    Jim
    Alamogordo NM
    Oh No, I would have to look back to see when for sure, But I think it was 5 years ago at least.
