05-07 brake tsb info
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 11secgt, Feb 12, 2008.
  1. Feb 12, 2008 at 4:29 PM
    11secgt
    11secgt [OP] Well-Known Member
    well i have been having a noise from my brakes on my 06 taco since day one usually after sitting for awhile and right after backing up but had no other issues with the truck so i never took it in...today i decided to call the dealer and surprise surprise i found out that there is a tsb for this, the number for it is br005-07 it covers 05-07 4x4 and prerunners and states that they will replace the front rotors and apply disc brake grease to help fix the problem..heres the best news...its covered the first 3 years or 36,000 miles.. so if you hear some noise then the rotors are covered...
  2. Feb 12, 2008 at 6:00 PM
    SteelCity
    SteelCity Wherever I May Roam
    Charleston, SC
    06 Radiant Rd DC LB PreRunner SR5 V6
    Optima Red/Stinger Terms, DT Headers, Empire O2 sim, Bluetooth, USASpec PA12TOY, Redline Struts, Extang Tonneu, OEM Bed Mat/front Skid/Roof Rack, Grillcraft Grille, Susp TSB, Toytec 1/2" front spacers, Raammat/Ensolite, Sony GTs, Curt Hitch, Tranny cooler, Wet Okoles, AFE Pro-Dry Drop in, Muth Sig Mirrors, Temp/Comp RVM, Silverstar HLs/Fogs, Royal Purple Diff/PS Fluid, Detroit Truetrac LSD, Hellwig rear sway bar, SG II, Filter Mag, 265/75/16 Nitto TGs
    Do you have a link to the TSB?
  3. Feb 12, 2008 at 6:08 PM
    muclhed
    muclhed Member
    2007 TRD Sport 4X4 Black Quad Cab 6-Speed Manual
    K&N 63 Series Cold Air Intake, Flow Master Dual Outlet Super 44 Mufler w/Dual Factory Chrome Exhuast Tips, 20x8.5 American Racing Chrome Razor 6 wheels w/ 265/50/20 Toyo Proxy ST tires. Putco Hybrid Chromed Alumininum 5" Oval Step Bars
    Yes.....please help with link that would be awesome
    this is good news
    Thanks
  4. Feb 12, 2008 at 6:09 PM
    11secgt
    sorry, no link...had the service advisor fax me a copy...it was dated 8/30/07 and revised on 9/12/07 if that helps...
  5. Feb 12, 2008 at 6:12 PM
    muclhed
    muclhed Member
    any possibility of scanning that copy into the computer....... and posting it??
  6. Feb 13, 2008 at 7:36 AM
    nd
    nd Radical Town. It's a hell of a place!
    Nate
    Greenville, SC
    07 TRD Off-Road 4x4 debadged
    De badged, 5100's, Black Toyota Baja wheels
    So what is the initial problem? noisy brakes? or does this cover any brake issue you have?
  7. Feb 13, 2008 at 7:47 AM
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    i think its noisy brakes. mine always squeal when i'm coming to a slow stop
  8. Feb 13, 2008 at 11:33 AM
    muclhed
    muclhed Member
    Thanks Phanton!!
