05-08 access cab 4cyl 5 speed 4wd
Discussion in '2nd Gen. Tacomas (2005-2015)' started by evansdmax, Jun 11, 2016.
  1. Jun 23, 2016 at 11:48 AM
    #41
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    98 Tacoma is not same cab room as 2nd gen. I know what you're saying tho. I went from 82 to an 05. World of difference. I'm 6' and have plenty of leg room in my 08 reg cab. I even put double cab storage bins behind the buckets and have same leg room. I actually have seat pulled 1 notch forward from all the way back just to fully depress clutch and still have nice comfortable angle on the back. Anyway, if I were you I would try for 2007 or newer to avoid the engine mount brackets caving in on the frame. Frames were reinforced in that area starting in 2007. Mostly it was a v6 issue tho.
  2. Jun 23, 2016 at 11:50 AM
    #42
    evansdmax
    evansdmax [OP] Well-Known Member
    Evan
    Western NC
    2017 TRD OR BBP 6 SPEED MT
    Already got the 06 but thanks
  3. Jun 26, 2016 at 9:18 AM
    #43
    evansdmax
    Evan
    Western NC
    Alright so it has a pound vibration sound coming from the front end.... I rotated the tires and it didn't help.... Put in a new wheel bearing from the side it sounds like it's coming from and the noise is still there. Any ideas?
  4. Jun 27, 2016 at 2:02 AM
    #44
    evansdmax
    Evan
    Western NC
    It ended up being the drivers side wheel bearing.... I got them both replaced and and ride/drives way better now!! Checked my mileage 1st tank and got 22.2 mpg's. That's exactly what I was after!!
  5. Jun 27, 2016 at 4:27 AM
    #45
    Ruggybuggy
    Ruggybuggy Well-Known Member
    NW ONT, CANADA
    2020 Tundra SX
    You will probably even get better that that for gas mileage. I see 24 mpg on the highway with my '12 AC auto.
  6. Jun 27, 2016 at 7:41 AM
    #46
    evansdmax
    Evan
    Western NC
    Hey man I hope so!! I'm gonna take it to the beach this weekend about 250 miles so I'll be able to get a good number on it the
  7. Jun 27, 2016 at 1:40 PM
    #47
    sleepsinshed
    sleepsinshed Member
    MA
    05 SR5 4x4
    I've been tracking the mileage on my 05 2.7 5-speed 4x4 for the five years I've owned it and I average 25 in the summer and 22 in the Winter, and it hardly ever sees the highway. Mileage is determined by driving style. I know there's nothing it can beat off the line, and merging onto the highway requires a reservation, so I tend to go lightly on the gas pedal; it's less frustrating that way. I also put an AFE dry filter in a couple of months ago. Haven't calculated the mileage since then, but if the stories are true it has to be at least 40 MPG </sarcasm>.
  8. Jun 27, 2016 at 3:46 PM
    #48
    evansdmax
    Evan
    Western NC
    That sounds awesome to me!!
  9. Jun 27, 2016 at 4:26 PM
    #49
    Ruggybuggy
    NW ONT, CANADA
    2020 Tundra SX
    If your looking for a little more performance and still want to get good gas mileage consider the LCE header. It's pricey but worth the money. It will drop the torque down in the RPM range and it's something you will definitely notice. There isn't much the 2.7 will respond to but it will with the header. When I bought my truck it was just a touch lacking in the power department. After the header it's now perfectly acceptable.
  10. Jun 27, 2016 at 4:29 PM
    #50
    evansdmax
    Evan
    Western NC
    Ok thanks did you go back with factory exhaust? Or something equally quiet? Bc I love it being quiet... My last two trucks were diesels with 5" straight pipe so muffler is nice!!!
  11. Jun 27, 2016 at 4:43 PM
    #51
    Ruggybuggy
    NW ONT, CANADA
    2020 Tundra SX
    The LCE header is a direct fit and takes about 2-3 hours to installing taking your time. I'm running the stock exhaust and with the header there is very little difference in the noise level. I also like a quiet ride so much so the I installed sound deadening matting in the doors and floor. It's almost as quiet as my '15 Camry.
  12. Jun 28, 2016 at 12:21 PM
    #52
    evansdmax
    Evan
    Western NC
    I appreciate all the insight
  13. Jun 28, 2016 at 4:27 PM
    #53
    evansdmax
    Evan
    Western NC
    One thing I would like to have is a limited slip rear dif.... How easy are these to come by? What do y'all do to fix the one wheel wonder problem?
  14. Jun 28, 2016 at 6:40 PM
    #54
    Ruggybuggy
    NW ONT, CANADA
    2020 Tundra SX
    I believe the LSD was available on the V6 TRD and was never available with the 2.7 4X4. Doesn't yours have the auto LSD button on the dash? My '12 SR5 has it and it works very well. In the winter if im doing the one wheel rear slip I can push the button and the slipping wheel's shoes apply to hold and transfer power to the opposite side.
  15. Jun 29, 2016 at 2:16 AM
    #55
    evansdmax
    Evan
    Western NC
    No mine is a 2.7 somebody just put the trd stickers in it. Lol I guess an aftermarket unit is the only way to go.... Idk much about the Tacoma world grizzly made the best ones for diesels
  16. Jul 2, 2016 at 3:51 AM
    #56
    evansdmax
    Evan
    Western NC
    Did the 250mile trip to the beach last night..... Everything went good.... Got 22 mpg but I ran 75-78 a lot of the time. Before j got it j was a little worried about the 2.7 on the interstate but it does really good Except on really big long hills.
  17. Jul 2, 2016 at 10:32 AM
    #57
    TacomaJack099
    TacomaJack099 Well-Known Member
    Jack
    Orlando Florida
    Blue 2007 Tacoma 2.7 / 5 speed AC 4x4
    same truck, 2.7, 5 speed, never got 22mpg unless I was going downhill both ways.
    run a few tanks to see what you really get.
  18. Jul 2, 2016 at 10:48 AM
    #58
    Ruggybuggy
    NW ONT, CANADA
    2020 Tundra SX
    Not sure why your not getting 22+ mpg. I usually see 23-24 mpg at 65-75mph and if I take it easy and at around 55mph will see 26. '12 acess cab 2.7 4X4 with auto.
  19. Jul 2, 2016 at 11:10 AM
    #59
    evansdmax
    Evan
    Western NC
    Yeah I don't know what you mean by wait a couple tanks..... The formula for hand calculating mileage isn't gonna change 3 tanks in.....just sayin? But I'm very pleased with the truck!!
