05-08 Overhead console w/temp & compass
Discussion in '2nd Gen Tacoma Parts Marketplace (2005-2015)' started by Sideways, Oct 14, 2012.
  1. Oct 21, 2012 at 10:24 AM
    Tunajoe13
    Tunajoe13 Well-Known Member
    Joe
    Parrish, FL
    05’ Base V6 4x4 extended cab
    20'' wheels, 34''x11" Toyo Open Country A/T II tires, 4.88 Gears, ARB Locking Rear Diff, ARB compressor, Fiberglass bed cover, Weathertech floor liners, Weathertech side window protectors, Allpro Apex front bumper, Allpro Apex rear bumper Allpro 3'' Expo rear leaf kit, Allpro hidden hitch receiver, 10'' aluminum drop hitch, Camburg 4'' spindles, Allpro uniball uca's, Ottonavi 6.5'' touch screen G.P.S, 09' Tailgate with factory reverse camera, Stampede hood protector, Raptor style grill and hood mesh (Homertaco), Piaa 5100 Fog lights, Volt HID's, Viper5704 Alarm with remote start, Limo tint, Scangauge II, TRD cai, URD 3'' Mk2 exhaust, Doug Thorley LT headers, URD Y-pipe, Unichip PnP Pcm, Unichip Flux2 display, Factory Sport hood....
    just had a problem with the temp sensor plugging into my 05 harness. Looks the same but it wont snap together and the display wont read anything. Light work though! lol. Any help would be appreciated. Thanks!! Hope I bought a working display. J/K
  2. Oct 22, 2012 at 12:30 AM
    adio
    adio Well-Known Member
    HI
    2015 INFERNO TRD PRO
    most likely resistor 510 is connected badly. re-soldering it is an easy and cheap fix. plugs are the same, but wiring is different.
  3. Oct 22, 2012 at 12:35 AM
    adio
    HI
    the ambient temp sensor should just snap into place on that plug. check the resistors 510.
  4. Oct 22, 2012 at 11:46 AM
    Tunajoe13
    Joe
    Parrish, FL
    It doesn't wanna snap together for some reason... I think the rubber seal in the connector on the truck is hard and stopping them from coming together. Got a connection though so its good enough for me rite now. I took it apart, found the 510 resistors and re-soldered them back to the board. works now! :) It was easy to see that one of the resistors were free from the connection point. I broke one tab off the display case and put a tiny burn mark in the screen when doing this repair. Luckily the burn is in the bottom corner and isn't seen at all when unit is back together and in truck. very easy to do I just drink way too much coffee to be doing things like this. My hands were shaking all over the place. LOL
    Thanks again adio!!
  5. Oct 22, 2012 at 12:24 PM
    adio
    HI
    no problem man. good to know you got it working.
