05-11 Front bumper removal.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by brandonbryan12, Mar 26, 2012.
  1. Mar 26, 2012 at 5:00 PM
    brandonbryan12
    brandonbryan12 [OP] Active Member
    Brandon
    Cranbrook, British Columbia
    OME 887x, Light Racing UCA's, Dakar leafs, Fox 2.5 RR rear shocks, Elite Offroad front bumper, Pelfreybilt rear bumper, Famous fabrication sliders, RCI skid plates, OVTuned
    I removed my front bumper this weekend and installed an Elite Off-road front bumper. Here's how I removed the front bumper. It was my first time doing this so if there's a better way to do things please chime in:)
    I started out by removing the grill, this is done by removing the 2 screws and 2 clips on the top of the grill. (The picture shows the passenger side clip and screw, its the same on the drivers side)
    http://www.tacomaworld.com/forum/attachment.php?attachmentid=144196&stc=1&d=1332802595
    I didn't have a clip remover so I just used a flat head screw driver to pop up the head of the clip, than pull the clip out.
    http://www.tacomaworld.com/forum/attachment.php?attachmentid=144199&stc=1&d=1332803486
    The removed clip.
    http://www.tacomaworld.com/forum/attachment.php?attachmentid=144200&stc=1&d=1332803603
    Once the 2 screws and 2 clips are removed pull the grill straight up. It is held down by 2 clips so it takes a little force.
    The bumper skin is held in place by 7 clips like the grills clips (3 on top and 4 below the bumper), 6 screws and 2 other clips (little different in style located 1 on each side, inside the wheel wells.
    Remove the 3 clips on top. (2 of the 3 pictured)
    http://www.tacomaworld.com/forum/attachment.php?attachmentid=144202&stc=1&d=1332804294
    Remove the 4 clips below the bumper skin. (2 of the 4 pictured)
    http://www.tacomaworld.com/forum/attachment.php?attachmentid=144205&stc=1&d=1332804425
    Remove the 6 screws. (2 below the bumper skin are pictured)
    http://www.tacomaworld.com/forum/attachment.php?attachmentid=144207&stc=1&d=1332804701
    Here's a picture of the other screw (inside the horse shoe shaped hole) located in the wheel well, the other clip is also in the picture which you'll have to remove.
    http://www.tacomaworld.com/forum/attachment.php?attachmentid=144208&stc=1&d=1332804985
    Tape the bumper and below the headlight to avoid scratches during removal.
    http://www.tacomaworld.com/forum/attachment.php?attachmentid=144209&stc=1&d=1332805235
    Now pull the bottom of the bumper skin upward, than jiggle each side of the bumper until it releases. You gotta hold your teeth right but it'll come off.:D
    Here's a few pictures of the bumper after removal.
    http://www.tacomaworld.com/forum/attachment.php?attachmentid=144214&stc=1&d=1332805834
    http://www.tacomaworld.com/forum/attachment.php?attachmentid=144215&stc=1&d=1332805834
    http://www.tacomaworld.com/forum/attachment.php?attachmentid=144216&stc=1&d=1332805834
    If you need to remove the bumper sub assembly, remove the 6 nuts.
    http://www.tacomaworld.com/forum/attachment.php?attachmentid=144217&stc=1&d=1332806094
    I had to pound a screwdriver in-between the aluminum sub assembly and the steel frame numerous times on both side to get it to release from the bolts.
    sallad4x4, jjew18 and NaZRaQ like this.
  2. Mar 26, 2012 at 7:07 PM
    whiteboy
    whiteboy Well-Known Member
    Cody
    Glendale, AZ
    '06 TRD sport
    Kings, alcans, 33's blah blah read my build thread in sig
    I'll be doing this in a month or so. Thanks for the write up.
  3. Mar 26, 2012 at 8:27 PM
    ROGU3 PR3DATOR
    ROGU3 PR3DATOR Space Shuttle Door Gunner
    Jake
    Eagle River, Alaska
    MGM 2011 TRD Off-Road
    Lifted, Supercharged, Armored, and lots more
    Fixed. Im also attaching the PDF I used for doing this when I did this last week. Nice write up though.
    NaZRaQ likes this.
  4. Mar 26, 2012 at 8:43 PM
    907taco
    907taco Alaskan Assassin
    Bobby
    Alaska
    2010 BlackSandPearl 4x4
    ultimate lift kit ( toytec ) ome dakar leaf pack , w/ extended length billies, LR uca's, Pro comp 7089s, KM2's 285 70 17, neoprene seat covers, weather techs, CBI sliders w/kickout, URD ss, cab mount chop, VHT night shade tint>tails,3rd B-light. Debadged. Grillecraft grille, rear diff breather mod. CBI Moab front bumper, warn M8000 winch, HID kragens 7", Hella's micro fogs. retrofit headlights HIDS, LED solutions maps/license! 886 back up light mod,
    Nice write up, I wish I had this when I installed my CBI bumper last yr. this will help someone for sure. Rep for you man
  5. Mar 26, 2012 at 8:46 PM
    907taco
    Bobby
    Alaska
    And your 3rd post to boot!
  6. Sep 3, 2012 at 5:13 PM
    jdk52
    jdk52 Bro do you even 'Merica?
    Utah
    11 SR5
    3 inch OME lift kit, rear diff breather mod, cb install, sliders, brute force fab front end.
    just what I needed.
  7. Jun 15, 2013 at 11:50 AM
    Infra
    Infra Well-Known Member
    Az
    2010 MGM DCSB 4x4 TRD OR 6spd
    CBI Bushmaster 2.0 rear bumper with swing out tire carrier & fold down camp table, CBI Moab 2.0 front bumper, Warn M8000-S, Icon 2.5 RR CDC Extended travel CO's with 700lb springs, Icon 2.5 RR CDC rear shocks, Icon hydro bumps, Total Chaos uniball UCA's, All Pro Expo leafs, U-bolt flip kit, Softopper, diff breather mod, extended rear brake lines, Grillecraft mesh grille, Elusive Elements behind grille light bar with B.A.M.F. LED light bar brackets, okLEDlightbars.com 20" double row LED light bar, Relentless Fabrication hood cb antenna mount, Wilson Silver Load CB antenna, Uniden 520 Pro XL CB radio, Wet okole seat covers, Weather tech floor liners, Weather tech in channel window deflectors, trasharoo spare tire trash bag carrier, Box Rocket 2nd gen bed rack with (2) 2 gallon gas rotopax mounted on drivers side, (2) 2 gallon water rotopax mounted on passenger side, (1) 3 gallon gas rotopax & (1) 2 gallon gas rotopax mounted on CBI swing out, Avid weld on sliders, Mattgecko LED bed light
    Sub'd for later reference
  8. Jun 15, 2013 at 12:04 PM
    XXXX
    XXXX Well-Known Member
    sKiP
    05 Prius
    see the other posters pics above....I just copied them
    clips are all under the bumper (see the blue ones). if you can reach them by hand while it's mounted have at it. if you can't - Just an FYI the bumper removal is VERY simple to do. Something like 4 screws and a couple clips. I had mine off in less than 30 minutes to put my lower grillcraft in many years ago.
  9. Aug 15, 2013 at 10:12 PM
    pmosin
    pmosin Well-Known Member
    SoCal
    07 Access Cab 4x4 TRD 6spd
    ARE Camper shell
    Thanks for this thread, this guide worked perfectly.
    The original bumper skin on my '07 had been repainted (poorly) by the previous owner, and the clear coat and paint started to self-destruct. I finally got lucky on Craigslist with a user silver bumper skin in very good shape that I found locally for $45.
    Removal and installation of new bumper skin took me 2.5 hours, including cleanup.
    A few extra tips:
    1. Before doing the job, you may want to buy a few extra grill clips, bumper clips, and wheel well "screw" clips. I ended up breaking a few popping them out, many were stiff with dirt/mud. FYI, the grill clips are longer than the bumper clips (at least the ones on the bottom, a bunch of mine were missing from the owner's previous repair).
    Also I think "screw" like clip in the wheel well must be turned 1/2 turn counter-clockwise (so that the "cut" in the top of the screw is vertical) before popping it out.
    2. To remove the fog lamp, just twist the rear connector about 1/4 to 1/2 turn counter-clockwise.
    3. When removing the bumper, on each side near the bumper flares, there is a small metal hook that the bumper plastic clips into. Be careful popping these up and out, because the plastic of the bumper is small and weak in that spot.
    4. To remove the entire fog lamp assembly (easiest after removing the bumper skin altogether), push the tabs in on the black plastic retainer that surrounds the fog lamp adjustment screw (at the bottom of the fog lamp), then while push in the 2 black tabs at the sides of the fog lamp assembly (they stick out into the bumper plastic), push the whole thing out towards the front of the bumper.
    5. Before reassembling, clean all plastic parts well using a good plastic cleaner + protectant like 303 Aerospace Protectant, including all of your bumper clips...how often will you be in here to clean anyway?
    Reassembly works perfectly in reverse order, without headaches.
    I'm attaching some photos of the results.
    Before:
    Bumper removed:
    After:
    BassAckwards likes this.
  10. Aug 20, 2013 at 7:13 PM
    Got2ryde
    Got2ryde Well-Known Member
    Ryder
    Maryland
    AC OR 6spd silverstreak
    Off Road tow pac. GTCovers wetskinz seat covers, Direct wired Escort 9500xi, Leer 180 w/ARB awning, bed mat, extra d-rings, rear dif breather relocated, Weathertec mats, Elite front with Warn M8000-s and Rigid D2's, BAMF sliders, ABS killswitch, Kicker Hideaway sub, UltraGauge, ATO rear with flush mount duallys, FJ Trail Team black rims w/Duratracs.
    Subed for good write up. About to install my Elite!!!:D
  11. Aug 21, 2013 at 10:52 AM
    pmosin
    SoCal
    ARE Camper shell
    FYI, I was looking thru a few online Tacoma fiches and I had trouble finding where the bumper clips and grill clips are listed. Finally tracked down a fiche that shows it clearly:
    http://www.villagetoyotaparts.com/s...=2007&ukey_driveLine=6162&searchString=bumper
    Part #52161C AKA 52161-02020 AKA 52161-0K040 AKA 52161-16010
    They sell 'em on Amazon and Ebay as well for less, like here, 20 pcs for $6.50 + free ship:
    http://www.ebay.com/itm/20x-Rear-Bu...Parts_Accessories&hash=item484d457283&vxp=mtr
  12. Jul 4, 2014 at 7:49 AM
    jasclair
    jasclair Well-Known Member
    joshua
    Bend oregon
    Current: BHLM, plasti dip badges/bumper, Satoshi homer taco style grille, custom TRD, pack rack Marshall fab, window tint,interior paint job, ome lift,wheels spacer, white light interior, retrofit headlights.
  13. Jul 4, 2014 at 10:19 AM
    XXXX
    sKiP
    05 Prius
    No need to post in necro threads to sub to them.
    Go to "thread tools" at the top right and click on it. A drop down window will appear. Click on "subscribe".
  14. Sep 16, 2014 at 10:15 PM
    BigD91
    BigD91 Well-Known Member
    Andrew
    Bay Area
    08 Double Cab 4x4 TRD Sport
    Great right up thanks!
  15. Nov 5, 2016 at 8:08 AM
    NaZRaQ
    NaZRaQ Well-Known Member
    Zee
    Denver
    2024 TRD OR Tacoma hybrid
    great write up, I'll removing stock to install a pelfrey bumper this weekend.
  16. Nov 5, 2016 at 8:59 AM
    BR Pipke
    BR Pipke Well-Known Member
    Drayton Valley Canada
    11 TRD short box 6speed std with 3" lift bilstein 5100 struts pro comp UCA AFE air cleaner and throttle spacer ultra rims 265-70/18 dual exhaust
