05-15 2wd to 4wd conversion guide (for dummies)
Discussion in '2nd Gen. Tacomas (2005-2015)' started by pdaddy, Apr 11, 2021.
  1. Apr 23, 2021 at 1:29 PM
    #61
    Ricardo13x
    Ricardo13x YT: @UrbanOpsOffRoad IG: @urban.ops.offroad
    Upland, CA.
    05 OR DCSB ProRunner(4x4 conv.), Chevy 63”s, NWF EcoCrawler, 35”s
    Random stuff. Oh! and converted to non ADD 4x4.
    What do you guys think? Good or pass? I used 3/16” mild steel. Setting on the machine was 18.5v / 175 ws. As you can tell I did not cut the original piece, I just added to it. With those settings I had proper penetration.
    ohcaltexscar, pdaddy[OP] and whatstcp like this.
  2. Apr 23, 2021 at 1:41 PM
    #62
    Ricardo13x
    Upland, CA.
    Seems like I will have about an 1 1/2 of clearance. I’ll be doing the cab hole, mount of trx case and lever today at night
    whatstcp[QUOTED] likes this.
  3. Apr 23, 2021 at 1:42 PM
    #63
    t.hornstra
    t.hornstra Well-Known Member
    Ted
    NorCal
    White with 4 wheels
    Little this. Little that 4x4 Swap’d PreRunner
    looks like it’d work for the trans. You likely won’t be able to mount up a mid skid with it hanging that low though.
    whatstcp and Ricardo13x[QUOTED] like this.
  4. Apr 23, 2021 at 1:43 PM
    #64
    Ricardo13x
    Upland, CA.
    It’s not that bad honestly, seems likes it’s going to be at the same height of the bottom of the transfer case(which this thing will provide some extra protection.)
  5. Apr 23, 2021 at 1:48 PM
    #65
    t.hornstra
    Ted
    NorCal
    White with 4 wheels
    true but mid skids come up the backside of that crossmember and bolt to the back. They aren’t deep enough mounts to get the holes lined up. @foxrcing07 and I both ran into that issue with RSTs crossmember being too thick.
    Ricardo13x[QUOTED] likes this.
  6. Apr 23, 2021 at 1:51 PM
    #66
    Ricardo13x
    Upland, CA.
    Expect some chopping action once it’s on the road then. :anonymous:
    whatstcp likes this.
  7. Apr 23, 2021 at 1:59 PM
    #67
    foxrcing07
    foxrcing07 KO7FOX
    Morgan
    Modesto, CA
    2019 Raptard 2001 TJ
    Dirt
    Yup and still not happy about it.
    I plan on building a custom crossmember down the road, just need to finish a few other projects 1st.
  8. Apr 23, 2021 at 2:32 PM
    #68
    6 gearT444E
    Deep South
    Herculiner Hootus
    Looks good to me, just keep an eye on it. I'd have added a plate on each side to tie between the front/rear of the plate here, but I think what you have will work just fine.
  9. Apr 24, 2021 at 9:35 AM
    #69
    adauto10
    adauto10 Well-Known Member
    Alex
    07 Tacoma prerunner
    Leveling kit, tires, paint, lighting, etc..
    I’ve been wanting to turn my 07 prerunner into 4x4. I’m a broke college student right now but will definitely keep this thread in mind for when I’m ready. Great info in here. Exactly what i needed.
    Ricardo13x likes this.
  10. Apr 24, 2021 at 2:14 PM
    #70
    bswords
    bswords Member
    Putting together the ADD wire harness... anyone able to dumb down the already dumbed down instructions on what wire where?.. I’m pretty electronically illiterate.
    I have the ADD side wired up and ran everything to my switch (same switch as the suggested in this thread). Mostly confused on what wires to the 12v, and where to locate a 12v source. The illumination positive and negative just go to any green wire under dash?
    thanks for any help!
  11. Apr 24, 2021 at 2:22 PM
    #71
    t.hornstra
    Ted
    NorCal
    White with 4 wheels
    There’s a crude drawing someone sketched up here somewhere. Lemme see if I can find it.
  12. Apr 25, 2021 at 1:49 PM
    #72
    bswords
    bswords Member
    Here is what I’ve got wired up... where am I going wrong? Tapped into that 4wd 20amp fuse for the 12v, still confused on wire location to spice for pin 9 & 10. C99020DA-A5BF-4300-85C6-C96A93BE71C1.jpg
  13. Apr 25, 2021 at 2:09 PM
    #73
    6 gearT444E
    Deep South
    Herculiner Hootus
    That look good to me though don't remember any gray wire on the ADD connector, should be a green/black wire. Pick whatever you'd like for illumination. Dimmer function or on content with tail lights? That will determine your choice of wiring. You don't need the dimmer hooked up for the switch to work, you can decide later to do that if you want.
    Switch pin # - ADD side
    1 - keyed +12V
    2 - Red wire from ADD connector Pin 1
    3 - Pink/Blue wire from ADD connector Pin 5
    4 - Light Green wire from ADD connector Pin 6
    5 - Black/White wire from ADD connector Pin 2
    6- keyed +12V
    7 - Light Green/Black wire from ADD connector Pin 3
    8- keyed +12V
    9 - Illumination Negative
    10 - Illumination Positive
  14. Apr 25, 2021 at 2:25 PM
    #74
    pdaddy
    pdaddy [OP] WeLl-KnOwN mEmBeR
    Preston
    Central AL
    ‘13 DCSB Converted Prerunner 4wd
    Mine has the grey wire in pin 3 but everything works fine
  15. Apr 25, 2021 at 2:43 PM
    #75
    6 gearT444E
    Deep South
    Herculiner Hootus
    that's good to know, sometimes Toyota likes to change wire colors even though they have the same function as before.
  16. Apr 27, 2021 at 10:11 AM
    #76
    pdaddy
    Preston
    Central AL
    So you just flipped it upside down? That’s pretty cool, I haven’t seen it done that way before! Looks good, as others have mentioned it may interfere with a transfer case skid plate but you’ll likely be doing a custom skid anyway if you want one.
    To give you an idea, I ended up welding angle iron onto the backside of my transmission skid (wanted to avoid using the crossmember bolt holes) and bolting the lip of my transfer case skid to that. It 110% ugly af but it works alright lol
    92086B36-EA0D-40EF-8299-AD76ED78B0E0.jpg 433AE92F-BADE-4C0E-A41A-F776A6F8C8ED.jpg A23C5DB9-19E1-4B28-AF5C-CD135A6D89D2.jpg
  17. Apr 27, 2021 at 10:32 AM
    #77
    jowybyo
    jowybyo Well-Known Member
    Joe
    Baltimore, MD
    '14 MGM DCSB Postrunner 4wd Conversion, Debadged
    I like your idea for attaching the t-case skid to the transmission skid. It looks like the back edge and the frame attachment points might bend pretty easily though. Consider adding some vertical stiffness to them.
  18. Apr 27, 2021 at 10:47 AM
    #78
    pdaddy
    Preston
    Central AL
    Good idea. One of these days I need to add stiffness to all of the skids, they’re not gusseted
  19. Apr 27, 2021 at 2:48 PM
    #79
    Ricardo13x
    Upland, CA.
    Conversion complete. Everything working as it should, with plenty of room for all ranges nothing cut outside the bottom part of the coin hole. Man I feel so relieved.
  20. Apr 27, 2021 at 5:15 PM
    #80
    pdaddy
    Preston
    Central AL
    Man that’s awesome! Congrats it’s quite the accomplishment:thumbsup: one more step, gotta change that TW vehicle description lol
